stock 403 w/ #7 heads
Old October 1st, 2018, 08:14 AM
Via3d's Avatar
IF I have a stock 403 and if I put stock #7 heads on the 403, how much horsepower / torque gain is reasonably and roughly expected ? (compression bump?)
All else stock except dual 2.5" exhaust. Qjet is 800cfm.
Via3d is offline
Old October 2nd, 2018, 06:14 AM
AZ520's Avatar
25 horsper
AZ520 is offline
Old October 2nd, 2018, 06:17 AM
oddball's Avatar
Some? Maybe in the 30-40 range? The stock cam isn't exactly anything to write home about, so it'd definitely be best to do a cam swap while you're in there.
oddball is offline
Old October 2nd, 2018, 09:28 AM
brownbomber77's Avatar
Better off cutting .030 off it unless you're using one of Smitty's .011 head gaskets. Otherwise, it's a bit of a lost cause because you're adding .030 of gasket material.
brownbomber77 is offline
79T/A
October 12th, 2015 06:58 PM
Cjs1969
November 18th, 2012 05:29 AM
My1st olds69"S"
May 10th, 2012 06:12 AM
brewcity
April 1st, 2011 07:41 AM
gold66
April 27th, 2008 03:00 PM
Quick Reply: stock 403 w/ #7 heads
