stall question
stall question
iv got a 1972 cutlass with a built 350, edelbrock heads bigger cam and higher compression. i think iv got 373 posi gears cuz i spun the wheel one time and the drive shaft went arounf 3.75 times. the car seems like it needs a stall with the cam being a higher rev cam? im not sure on the cam specs, any idea on a good stall, it just a street car?
also what trans would be in this car its a 3 speed?
thanks
thanks
The trans could be a TH350 or TH400 you can tell them apart by the pan. The th350 is close to a square shape more like a pentagon and the th400 looks way diffrent. The stall is an issue because with out knowing the specs of the cam its hard.
stlregal
November 17th, 2010 04:54 PM
