Square primary tubes?
Old January 12th, 2010 | 08:39 PM
The Stickman's Avatar
Ok here is an odd question. I am considering doing a twin turbo set-up. Now here's my question. The exhaust ports are square and the center two ports essentially have a retangular exhaust port. Now I was thinking on making a simple straightforward log type manifold. And I was thinking the easiest way to do it. Since the ports are already square coming out of the head and since this will be a simple log tupe manifold. Could I use square box tubing for the primary tubes at the very least for the center retangular port?
Old January 13th, 2010 | 07:19 AM
You will get stagnation of flow in the corners, so I would not recommend it.
Old January 13th, 2010 | 11:10 AM
Actually the primary tubes will be straight. Like this. Think these only backwards. Instead of back and down forward and up sligthtly. Also after posting I also thought it souldn't be a problem as the intakes use square runners.
Old January 13th, 2010 | 12:11 PM
Intakes use square runners as a compromise between optimum flow and manufacturing cost. Note that tunnel ram intakes, tuned port intakes, and engine designed in the last 20 years use round intake runners.
Old January 13th, 2010 | 12:17 PM
To add to my previous post, the whole point of your exhaust manifolds is to feed as much exhaust energy as possible to the turbos. Anything that disrupts the flow and/or cools the gasses will reduce the energy in the flow and reduce the boost and thus HP from the turbos. Will square tubes work? Sure, but you'll be giving up some HP.
WTony
December 3rd, 2014 04:16 PM
WTony
September 12th, 2014 06:10 PM
DAN76
July 24th, 2009 09:01 AM
GoBigRed
Brakes/Hydraulic Systems
June 7th, 2008 08:21 AM
mpothuizen
December 3rd, 2006 01:40 AM
Quick Reply: Square primary tubes?
