Solenoid assembly
Old December 23rd, 2013, 07:18 AM
Macadoo's Avatar
Solenoid assembly
I got a little overconfident and disassembled my solenoid without taking pictures. Do I have it assembled correctly? Is this the proper orientation for the cap? And for the life of me, I can't figure out where the extra spring goes. It popped out when I removed the cap and didn't get a chance to see it in place. And is the "R" terminal oriented correctly?
[IMG][/IMG]
[IMG][/IMG]
Thanks everyone
Macadoo is offline
Old December 23rd, 2013, 07:24 AM
Looks right to me, but I don't remember that second spring. Hmmm...
Flip the big washer over to its other side, too.
MDchanic is offline
Old December 23rd, 2013, 07:49 AM
I was going to say that you should at least file the copper disk and the two terminals smooth before reassembly (yes, I see that you've rotated one of the terminals in the cap to the non-pitted side).
joe_padavano is offline
Old December 23rd, 2013, 08:21 AM
Macadoo's Avatar
Yeah, took the pic before I cleaned everything and exposed new copper. Good to go there. No ideas about the other spring? Weird. It's not shown in the exploded view in the manual either. Could it be an extra, like a replacement? Seems like a stretch.
Macadoo is offline
Old December 23rd, 2013, 09:14 AM
NO! That 'extra' spring is NOT extra. One goes behind the contact assembly and the other goes on top. If your copper contact assembly is staked on you can't rotate that disk, but you can clean it with some 400 grit paper.
Be very careful putting the phenolic cover back on because that material can be brittle and crack very easily. If you use loctite blue on the securing nuts it should hold nicely and not come loose.
Allan R is offline
Old December 23rd, 2013, 09:30 AM
Macadoo's Avatar
Allan, if you mean there is a spring underneath the disc and one on top, then yes, I have three springs in all; the two in the pic and another that is exactly like the spring on top. Not sure what you mean by "behind the contact assembly".
[IMG][/IMG]
The disc is staked on so I just took it to my wire wheel.
Macadoo is offline
Old December 23rd, 2013, 09:43 AM
Ok, that's good! 2 springs is what you're supposed to have. No idea why you'd have 3 of them unless one fell off the stake and the assembler just reached for another instead of picking it up? Contact disk looks good. I didn't paint my solenoid casing, it shouldn't need it. If anything, parts that need to look 'natural metal' can be clear coated with high temp satin clear. Results are very good.
Allan R is offline
Old December 23rd, 2013, 10:02 AM
Macadoo's Avatar
Okay, extra parts rolling around inside an assembly are NOT helping the inexperienced DIYer, lol. Thanks Allan.
Macadoo is offline
stratoblues
September 1st, 2014 06:52 AM
olds67
September 11th, 2009 12:45 PM
442_Mustang
July 21st, 2009 03:43 PM
woodie582
November 15th, 2008 03:57 PM
Chumley
April 11th, 2008 07:08 PM
Quick Reply: Solenoid assembly
