Smokey the Oldsmobile Bear !
Old April 19th, 2013 | 06:15 PM
  #41
nj_cutlass72's Avatar
Eric - I did and its dry however i havent cranked the
engine for about a week.
Old April 19th, 2013 | 06:21 PM
  #42
If you put a length of vacuum hose on the end of the steel line that comes up from the transmission, and suck on the hose, you should be able to pull a strong vacuum and have it hold.
If it leaks down, that means there's a hole somewhere - probably the modulator diaphragm, though a pinhole in the steel line, or a floppy 3" length of hose between the line and the modulator are also possible.
Old April 19th, 2013 | 06:25 PM
  #43
m371961's Avatar
And, if you get a mouthful of ATF, you got a bad modulator.
Old April 19th, 2013 | 06:27 PM
  #44
Yup.
Old April 19th, 2013 | 06:46 PM
  #45
what's worse ATF or radiator fluid ingestion?
Old April 19th, 2013 | 07:21 PM
  #46
It is highly doubtful that you would actually ingest any, but if you did, then it's probably a toss-up, mostly because neither one is particularly toxic through a gastrointestinal route in small quantities.
The LD50 of antifreeze is about 4.7g/kg, which is to say that a 220lb man would have to drink 470g, or about a glass or two, of 50:50 antifreeze to have a 50% chance of dying from it.
I don't know the toxicity level of ATF, but it would be on par with that, probably a bit less toxic, actually.
The problem with ATF is that if you actually drank it, its surface tension is significantly less than that of water, which might allow droplets of it to bounce into your windpipe, causing an aspiration pneumonia which could later be fatal.
However, if you just sucked a drop onto your tongue (or even caught a mouthful), it shouldn't be a problem.
Has a mouthful of gasoline ever bothered you for more than a few hours?
Old April 19th, 2013 | 07:53 PM
  #47
good reply, definitely sounds CSI
Old April 21st, 2013 | 12:14 AM
  #48
MaxDog's Avatar
Originally Posted by nj_cutlass72
i'll give this a try, my car does produce white smoke and I wonder if this is a fix for me as well... did you guys notice a significant amount loss in tranny fluid?
Yes, alot. So much so that it effected the ability of the transmission to go into reverse. The smoking would happen after sitting at idle for a while, such as at a stop light, then upon accelaration, tons of smoke for a few seconds. Then it was ok.
Old October 2nd, 2013 | 08:18 PM
  #49
Tony72Cutlass'S''s Avatar
That's a very tough one.
If you have enough clearance, I would try centerpunching the screw EXACTLY in the center, and drilling the center out, a small amount at a time, then, when it's almost drilled out, see if you can get an EZ-Out to turn it - there are some nicer ones available these days at places like Sears.
If the EZ-Out doesn't do it, then drill a bit bigger and try to tap the hole to the right size - this might losen the remains enough to get them out. If the remains don't come out, then try using the hole you tapped.
If the hole is too screwed up, then HeliCoil it and you're done.
Of course, if you don't have the clearance to do all that, then it's got to come out.
This JUST happened to me....
Sad Tony.. all i wanted was a new modulator..
I seem to have no room under there, do i need to remove the crossmember?
I think the bolts are seized on my crossmember too..
Old October 2nd, 2013 | 08:19 PM
  #50
Originally Posted by 61reoldsman
Thats gonna be tough Eric without dropping the trannie somewhat to access that bolt ,it is a very tight squeeze in there ,I may just leave it as is for now ,I Mc Gyver'd a replacement to hold the modulator in that seems to be working .
I do believe that vacuum is holding it in there tight enough so it's not loose .
Tell me what you Mc Gyver'd!
I'm having this same issue and it's freaking me out. I broke the bolt at the transmission.
Old October 2nd, 2013 | 08:31 PM
  #51
Holy f___ing s__t. I just answered your post on the other thread, and essentially retyped the response that you quoted above, without even realizing it.
I had to re-read the one here to be sure it wasn't the one I had just written.
Consistency...
Old October 3rd, 2013 | 06:47 AM
  #52
Consistency...
Wait, i just saw this, that's quite impressive.
Old October 3rd, 2013 | 10:55 AM
  #53
61reoldsman's Avatar
I'll take a picture of the bracket I made to hold the modulator in place .
I wasn't about to pull the transmission so the next best thing was to try and hold the modulator in place .I believe there's some vacuum that holds it in place too , and also I fixed this last year and it's still holding
Old October 3rd, 2013 | 11:38 AM
  #54
That would be SUPER helpful, i'm hoping to make something that will hold it in the meantime that i can drop the transmission and fix it properly...
Old October 3rd, 2013 | 03:58 PM
  #55
hey Tony here's a couple of pics I just shot tonite ,hopefully you can make one like this to work for you ,it's kind of MacGyver style but it works ,like I said I didn't want to pull the trannie and I was able to move my trans X member so i could have a bit more room .Good luck...Brian
Old October 4th, 2013 | 01:04 AM
  #56
So i almost made EXACTLY the same thing as you, i just ripped an old idle stop solenoid bracket off an old carb i had. THanks for the advice.
SO now that the modulator is in...
The car won't shift out of first gear unless i slam the pedal to the floor.
Old October 4th, 2013 | 09:24 AM
  #57
Two things I can think of , make sure you have manifold vacuum to the modulator and the trannie fluid is full when hot ,maybe Eric has some other ideas too but that's all I got Tony
Old October 4th, 2013 | 10:31 AM
  #58
+1. Check the vacuum waaaaay down at the modulator - there could always be some crud in the tube.
Also, if you want to really check it, run a vacuum hose into the cabin and suck on it while you drive (or use one of those fancy newfangled vacuum pumps). If it's got good vacuum on it, it should shift lower.
Old October 4th, 2013 | 10:50 AM
  #59
Wow, really? You think that'll do it. I dont have a vaccum pump but i can kill a rootbeer float in 30 seconds flat.
I was thinking of putting a small hose clamp around the connection at the modulator.
Or just buying 4 feet of vaccum tubing and running it to manifold vaccum and be done with it...
Old October 4th, 2013 | 11:43 AM
  #60
Or plug the lower end and suck on the upper end, then hold your finger over it to see if ti leaks down, then unplug the lower end (leave it open) and suck on it to be sure you have a free flow of air.
Only takes a minute.
Old October 4th, 2013 | 02:50 PM
  #61
Sure enough, I unplugged the manifold vacuum from the engine and I blew into the end, air rushes through so there must be a leak...
I just bought 5 feet of vaccum line and I'll replace the whole thing and see if it helps..
Old October 4th, 2013 | 06:23 PM
  #62
Excellent ..let us know how it works out Tony.
Old October 4th, 2013 | 09:59 PM
  #63
Gentleman,
The old steel modulator line was broken!
I replaced it temporarily with a full 5' length of tubing...
AND MY CAR SHIFTS LIKE A DREAM NOW.
At part throttle, you can't even tell it's shifting.
At Full throttle,the tires chirp. It's the perfect beautiful delicate balance between power and finesse.
Thanks all for your help and encouragement!
Old October 5th, 2013 | 03:40 AM
  #64
There, ya go, Tony: a nice, simple problem.
Glad you figured it out.
You're welcome!
Old January 5th, 2014 | 11:14 AM
  #65
66Olds88's Avatar
I've got a 1966 88 Convertible with a smoking 425. Will the AT module issue/possibility apply to this engine also? Thanks.
Old January 5th, 2014 | 11:37 AM
  #66
how is your oil level, any loss?
Old January 5th, 2014 | 12:31 PM
  #67
Yes, it will.
Pull the vacuum line to the modulator and see if there is any ATF in it, then suck on it and see if the modulator will hold vacuum.
Takes all of about one minute.
Railguy
October 30th, 2011 03:56 PM
Jamesbo
July 1st, 2010 08:13 AM
Bluevista
November 22nd, 2009 05:24 PM
cutlassgal
November 13th, 2009 09:23 PM
FOUROUTAFIVE
November 10th, 2007 11:35 AM
Quick Reply: Smokey the Oldsmobile Bear !
