Small plug in freezeplug kit
Hi,its been a while since my last post,Ive been busy with my toy project. The question is where the small sheet metal plug in the plug kit is suppose to fit? It's about 1/2 inch in diameter.
Sounds like the access hole to the holey plug in the rear of the LH oil passage.
Be sure to replace the holey plug during the rebuild, and NOT use an unholey plug, or no plug at all. Even if your plugs kit came with a nice pretty new one.
Regards
Octania is right......
Looking at the rear(flywheel) of the engine, there should be 3 plugs .
The camshaft end plug(the big one), a NPT plug on the right of the cam, and the one to the left of the cam.
THAT'S where that plug goes, but be careful. There is ANOTHER plug BEHIND that press in plug that is also NPT and it has a 0.040" oil squirt hole in it to oil the dizzy gear. Don't fail to install that NPT holey plug or one with no hole. If you forget to install at all....little or no oil pressure.
If you install one with no hole....posssible burned up dizzy/cam gear(although there are arguments as to whether this hole is actually needed)
Make sure you put a little sealer on it to prevent an oil leak, and I like to stake it in place with a sharp chisel.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Best regards
OK! I have installed the treaded (NPT) plug with the oil hole thats lube the distributor gear. I have sealed the block with a sheet metal plug about 3/4´size, on the outside of that. That´s clear for me. The other NPT, plug and the big camshaft plug also. I have one leftover sheet metal plug 19/32´and this one confuses me.
Best regards
Best regards
Can't imagine where you'd put that extra one
what did you do with the two threaded plugs? Evidently you have at least two 'extra' parts in your kit.... the cup plug 19/32" and the 2nd threaded plug. This assumes you used one threaded plug in the aft end of the RH oil passage.
I am glad to hear that you did not put an unholey plug in the aft end of the LH oil passage.
Sarum
March 26th, 2015 09:14 PM
ds00469
January 25th, 2014 05:12 PM
