Shimming rocker arm pivots to adjust valve clearance
Old Jan 24, 2015 | 06:49 PM
  #41
Originally Posted by Arrowstorm
I have since read that you're supposed to do a compression test with all the spark plugs pulled out.
Ayup.
That 110psi is across the board with the plugs IN. So I don't know what difference that will make.
It'll be significant.
Try it when it's back together.
... he mentioned that his son did...
Ohhhhhhhhhhhhh...
The leakdown test was LAST on my list because I took for granted that because the heads were fresh, there would be no need.
... And, as we annoyingly repeat here, over and over, never ASSume, check everything, even the things that can't possibly be wrong, and especially the things that you just "fixed."
... the valve stems on the driver's side heads were uneven. I'll definitely have to point that out. I kinda feel now that they should have never left the shop like that.
Yeah. That was kinda incompetent, and kinda needs to be fixed free of charge, and, at this point, should be perfectly even when you get them back.
Old Jan 27, 2015 | 02:40 PM
  #42
Arrowstorm's Avatar
Olds Wagonmaster
I just dropped the heads off with the machinist. He was extremely cool about it.
I told him my plight and the first thing he said was I should have talked to him sooner. But I said that pulling the heads again was the last thing on my mind. He mentioned that he believes he got a bad batch of valve guides because another Olds guy in town had the exact same problem and actually bent the valve.
My valve wasn't bent. It was literally STUCK in the guide. It was so stuck that he had to hammer it out of there. He said that the stem would have eventually welded itself to the guide. I saw the stem. It was scuffed and scarred. NOW I understand how a valve can "stick". I didn't quite get it before. Metal expands when heated. DUH. Lol.
I mentioned about the uneven valve stems and he said he believed it was because of the guides. He didn't pull that one obvious valve out, but he did put a straight edge across and saw what I was talking about.
He immediately OFFERED to make it right with a new set of guides and a head gasket set.
I'll have them back in a day or two. I might put it all back together this weekend. I had already planned on sitting in front of the fire all day saturday outside drinking beer and jamming to some Irish folk tunes with some friends (I had two giant felled pines to cut up and so I've split more wood than I can burn), but.... I may go ahead and assemble the engine. If not, I definitely will during the week and report my findings.
Thanks for the advice and support!
Buz
Old Jan 27, 2015 | 02:53 PM
  #43
67 Cutlass Freak's Avatar
The new guides were not sized properly, honed to establish specified clearances, by your machinist. This needs to be done whenever new guides are installed.
If you did not have new valves before you need them now.
I call BS. The guides have nothing to do with valve stem height.
New guides will not correct your installed stem height. Does he have the proper tool to measure this?
You need to tear these back apart when you get them back and have an experienced Olds guy check them out with you. Did your machinist offer you any compensation for the time it's taken you to diagnose/ R&R these heads a second time? I don't care how nice this guy is... YOU NEED TO FIND ANOTHER MACHINIST.
Buz
Old Jan 27, 2015 | 03:15 PM
  #44
Hopefully he gets it correct this time. The previous post pretty much covered what most of us think.
Old Jan 27, 2015 | 03:38 PM
  #45
+1.
And I will emphasize that part of installing new guides is to ream them to the proper size when done.
If he had done that, you wouldn't have had a problem.
chasman414
Feb 11, 2013 10:43 PM
442bob
Nov 9, 2011 04:31 PM
chris83
Sep 22, 2010 07:51 AM
Tony Cutlass
Tech Editor's Desk
Jan 17, 2010 06:36 AM
Gary Lagacy
Sep 20, 2008 01:35 AM
