Rocker Arm Damage
Old Jun 13, 2015 | 09:27 PM
pmathews's Avatar
Rocker Arm Damage
Heard a small clicking sound this week and found a damaged rocker, 10k miles on the rebuild 14 months ago with regular oil changes. Is this a rare thing or a common failure? The other rockers were great.
Additional info: This was on the #7 cylinder on a '67 330, exhaust valve, and the exhaust valve tip looks great. Using stronger springs to match the higher lift cam (0.486"). Pushrod looked great. Perfect wear pattern on the other rocker tips.
We replaced the exhaust valves during this rebuild, kept the stock rockers, maybe the new valves are harder? Maybe stock rockers should all be replaced?
Old Jun 14, 2015 | 05:10 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It could be there was some wear and it maybe the factory hardening only goes so far? Could be harder valves and higher spring pressures are the cause. I would consider the Harland Sharp or Scorpion pedestal mount true roller rocker arms.
Old Jun 16, 2015 | 08:31 AM
pmathews's Avatar
What about Comp Cams Magnum Rockers? Anyone have bad experiences with these?
http://www.compperformancegroupstore...e=A8RockerArms
This is a cruiser, not a dragster, so I'd prefer a cost-effective option, but I don't want to waste money on a product that may eventually fail. Any advice would be much appreciated (thanks).
Old Jun 16, 2015 | 08:44 AM
Is you valve stem length the same for that rocker as the rest?
Old Jun 17, 2015 | 04:51 PM
pmathews's Avatar
I didn't measure valve stem length, I've since buttoned up the valve covers, but I'll measure next time.
Old Jun 17, 2015 | 04:55 PM
coppercutlass's Avatar
Chevy budget Olds powered
The roller tip rockers are fine for your application. Full rollers are just overkill. But with going to this rocker there is work involved . You will need to check for proper pushrod length regardless of what comes in the kit .
Old Jun 17, 2015 | 07:37 PM
Those are a decent rocker arm, I am running them on my 350 with stiff double springs and no problems. I am going to 1.72 ratio full roller Scorpion rockers shortly.
Old Jun 18, 2015 | 12:11 PM
pmathews's Avatar
If you want to sell the Magnum rockers, I'm in the market I need guideplates and studs, too. Just PM me with a price if they're available (thanks).
Old Jun 18, 2015 | 07:45 PM
Keeping the guide plates and possibly the studs. I will let them go really cheap. The 5/16 to 3/8 conversion studs are around $60.
CutlassLegend
Sep 21, 2011 02:56 PM
crholds442
Jan 20, 2011 09:23 AM
Gary Lagacy
Sep 20, 2008 01:35 AM
70cutty
Aug 15, 2008 03:14 PM
gibbo69olds
Apr 24, 2008 12:29 PM
