reving an Olds 350
reving an Olds 350
With such a short stroke, why can't the 350 Olds be reved as high as a Chev 350? I'm not trying to be a jerk, I'm honestly just wondering. Is it insufficient oiling for the bottom end?
- GoldOlds
- GoldOlds
........ I'm not trying to be a jerk ........
........ Is it insufficient oiling for the bottom end?
Norm
There are a number of things that limit peak RPM. Bottom end strength (4 bolt mains vs. 2 bolt, for example), bearing speed (Olds motors have larger diameter main and rod bearings, which increases the linear speed for a given RPM), reciprocating mass, rod strength, valvetrain float, and head port flow. You can certainly build an SBO that matches an SBC for power at a given RPM. AJ Foyt ran a 350 Olds (NOT a diesel block, by the way) in a Cutlass in NASCAR in the mid 1970s. That's why CJ Batten developed those aftermarket heads in the first place.
