Rev Limiter Question.
I have an original 1968 Rocket 350 engine i had rebuilt. It is all stock except for the mild cam that was put in it , HV oil pump and the 4 bbl rochester has been rebult with hi perf accel pump rods needle and seat and air orifices drilled out. I have a pertronics electronic ignition in the stock distributor and it has a rev limiter. What is the max rpm I want out of this motor? Where should i set the rev limiter? Any suggestions would be appreciated....T
You can have a cam that breathes to 7000, but if the valve springs let the valves float at 6000 then 5800 is your limit. It'll quit making power once the valves start to float anyway. There's no sense in spinning it past that point.
I'd set it at no more than 5200 or so unless you know exactly what spring is in it.
Actually imo the valvesprings will dictate what a safe rpm limit will be.
