Replacing Head Gaskets On My 330 (lots of pics)
So I am finally getting around to changing out the head gaskets on my 330 because once I got it running it had bubbles in the radiator and was losing coolant. Even though I only drove it maybe 5 miles. The weather here was almost summer-like over the weekend and I couldn't think of anything better to do so I took it apart.
The basic stuff was rather easy to remove, only an alternator and power steering pump for accessories.
I took a picture of the distributor position before removing it.
Upper rad and bypass hose, carb and intake, exhaust manifolds and then the heads.
There was a little debris in the lifter valley, but not bad and it cleaned up pretty well.
The heads have been off this engine before and they had been put back on opposite their original location. To my untrained eye it looks like the gaskets failed in multiple places and it makes me wonder if the head and block surfaces were cleaned up before reassembly the last time.
One of the nicest things about working on these older engines is the number of tools it takes to do the work. This is every tool I used to disassemble the engine to this level.
Getting this far along was pretty simple and fast, but I did find a few odd things along the way. There were some interesting things in the water jacket. The first goober looks like a glob of silicone and the second is clearly a leaf. Weird.
There were a few blocked water passages but I realized some of them were meant to be that way when I put the new gaskets in place. In the photos of the heads with gaskets still in place you can see other blockages as well.
I may get a little discussion about the way I clean things up, but I have never had any problems doing it like this in the past. Please feel free to offer criticism or instructions as you feel necessary though.
First thing I do is use a large scraper to clean off most of the junk and build-up. This leaves a remarkably smooth surface rather quickly. The scraper is from the paint section of the big box home improvement center. It is designed as a floor scraper I think. That is what I originally bought it for anyway.
After that I use a long flat board with sandpaper wrapped around it to get the metal surfaces nice and shiny. The board is a cut-off piece of a cubicle desktop and is extremely hard, flat, and fairly rigid. This is 120 grit I think. The photo shows only one hand on the board but I use two hands in the actual sanding operation to keep things flat and even.
Nice and shiny! The block and heads get the same treatment on all mating surfaces. It looks like a different milling machine was used on each deck surface of the block. Even the heads have a different milled finish on them.
I just use a few fine ScotchLock pads with a pneumatic die grinder, after scraping with a gasket scraper, to clean up the surface, but your system certainly looks like it works well.
I didn't get a shot of the cleaned up heads but I used a cup brush on the combustion chamber and scotchbrite pads in my angle grinder to clean up the valves themselves. All that pitting is just carbon build-up. The valves cleaned up pretty nicely.
While I had everything apart I took the fuel pump off and checked the timing chain. It felt reasonably tight and I was able to get a decent photo with my phone. You can see that the teeth on the cam sprocket are steel and there is blue silicone around the mating surfaces of the water pump and timing cover so it has been replaced.
I put the new gaskets in place and torqued the heads down. Not too bad for a single afternoon's work.
Did you take the heads to a machine shop to make sure that they weren't warped ?
If not , then I would suggest you pull them back off and do so. And pick up another pair of head gaskets when you do .
I have had very good results on piston crown carbon by spraying and soaking with Seafoam and then cleaning with a brass wire brush - repeat several times, and it's amazing how clean they can get.
I definitely advocate smoothing (not quite polishing) the rough casting surfaces of the combustion chambers, especially on high-compression motors, as I have observed reduced pinging when this is done (with measured CC volumes the same before and after, to compare apples to apples).
There were a couple items of concern that came up along the way. One of the rocker bridges is broken. The ends are discolored by oil so it has been broken for a while. Dunno if it was put back on that way by the person that took it apart previously of if it broke while in use after that. I could probably put it back on the way it is but for the price of a new one I think I should replace it.
The pistons, by comparison, had very little carbon build-up on them so I didn't worry about that too much. I also noticed along the way down this little trek that there is quite a ridge at the top of the cylinders so this engine will not be much longer for this world. As long as it runs and provides a few more good miles of service it will be replaced in the near future. Probably next winter. I didn't see much reason to put a lot more work into it at this point.
Yes, by all means replace the broken rocker bridge .
You can pick it up when you get the heads checked. If this thing was blowing bubbles in the coolant , then I can almost guarantee that the heads will need to be re-surfaced.
Dood! You're gonna guaranty from more than half way across the country, sight unseen, that my heads are warped because the gaskets failed? I'm pretty sure the gaskets failed because the engine wasn't cleaned properly the last time they were replaced. Which was probably because the original steel shim gaskets finally rusted out.
Yeah, I already bought a turkey tray before I took the engine apart. I'll contact Rock Auto and see if they will trade it for the other gasket set, and a rocker bridge. My last Cutlass didn't have the turkey tray in it either but I don't remember if it had the bolt-in tray. That was about 25 years ago.
Laugh all you want! You won't laugh if you have to do the job over because you DIDN'T check the heads .
I've only done this stuff for a living for close to 50 years . What the hell do I know ?
The block sanding is how I was tought years ago by a old school tech. I do like to use the scotch pads on my angle grinder or the 3m rubber ones
Looking good
Out if caution did you put a straight edge on the heads to check them ?
Looking good
I made a living at this stuff for a while myself. So did my Dad. I have enough experience to make educated decisions about what it does or doesn't need at this time of the engine's life. I appreciate your input and it is sound advice, but this engine is too worn out to wast time and money on the heads without a total rebuild.
It's a lot of work to throw away on the chance that you might be successful.
Anyway, it's you doing the work. I really do wish you the best of luck on it.
BTW it's not really nice to laugh at people.
You are just asking for trouble the way you are cleaning and re-assembling, just my humble opinion and speaking from experience with short cuts. Do it once and do it right.
The engines weren't blueprinted from the factory, as long as everything was within tolerance it would go together. A couple of people here have posted about blocks with one cylinder bored oversize from the factory.
Iron heads are much less prone too warping than alloy ones. Imo you shouldn't have any issues. Of course in an ideal world you would have the heads rebuilt like new.
On the other hand, if you hadn't a broken rocker bridge i guess you would have it all buttoned up and running the same day. Good work.
Fwiw I have lapped a warped head to a block using valve grinding paste when I was stuck out in the Boonies. It worked.
Roger.
If people make funny remarks, it makes me laugh. To indiscriminately tell me that my heads are warped when you have absolutely no idea about the history of me or my engine is bordering on ridiculous. Your experience is impressive, no doubt, so I'm sure your comment was meant to be educational. But you have no idea what my experience or skill level is so your comment was belittling. Be nice and people will be nice back!
If this were a fresh engine then yes I would have checked the deck and heads for straightness. I have a precision ground straight edge in my garage. If I were trying to build a performance engine, you bet it would go to a machine shop for blueprinting. This turned into a minimalist repair when I found 3~4 thousandths ridge in the top of the cylinder bores. If I get a couple of months of top-down motoring this spring and summer I will have been successful in repairing this engine. For now!
#32
Look, Guys! If this were a full-on restoration, or if I were absolutely going to tear the engine down completely and rebuild it then yes, I would throw the $$$ at it and do it all to your satisfaction. But if replacing head gaskets meant a tear-down and rebuild every time, there would be an awful lot of cars that would never run again. I mentioned that this engine was 45 years old earlier, well I was wrong, it's 48 years old. It has lots of wear on it. It's tired! Not every part that comes off an engine needs to be remanufactured to original tolerances every time it comes apart. This was an expedient repair to get a little more service out of a tired, worn out, 48 year old engine and have a little driving fun in the Hooptie this summer. If you want to offer advice something like, "If this were my engine, the heads would go to the machine shop for a rebuild." Or "The wear on that engine suggests it should be completely rebuilt so it can be reliable and road-worthy." But to tell me I'm a cheap bastard because I didn't put enough money into this tired old dog is not constructive in any way. Make your comments and follow them up with constructive suggestions or criticisms, not just snarky shots about how much money you have in the pocket book. Be nice! I promise that you will get to see a lot more work go into this car. Engine, trans, body, interior, the whole thing. This is not a daily driver so if I get a few miles of fun out of it before I tear it all apart, it was worth it to me.
#34
Hey you put your talent on display!When i pull a engine down that far i fix it to last! I don't band aid it for 5,000 miles or more! You stated it needed to be redone but you were not doing it! Hence snug in the pocketbook comment! I could careless if that motor works very long or not! You stated you also had many years of working on motors.Well back yard hacking don't count for much!! Now when you say your are doing this just to get by and going to do it right later leads to speculating.I would like to think you can really do a rebuild correctly. That being said no need to defend your position you put on your show. What i would like to see your real talent when you get ready. You can call me a hack when it comes to carpenter work! Have a good day.
#37
Go away moderator i am not bashing him! There is nothing wrong with doing a job like a backyard hack! Really!He admitted the motor needs to be redone correctly! If the shoe fits then wear it! Maybe you would do it this way but i wouldn't.I am thinking he really can do a quality job just not sound reasoning to band aid for a few months just because you can. I stand behind fix it right and be done.Have a good day ERIC.
#38
Maybe we should run a poll to see how many of you guys are snug in the pocket book. Fixing one this way when you are broke is one thing but to do this when you have cash that is another. When you know and state the motor needs a overhaul fix it to last.Have a good day all you guys that think i am wrong.
#39
