Rallye 350 abnormal rough idle
Old Apr 4, 2013 | 09:19 PM
jonesolds442's Avatar
RE: '70 Rallye 350
Hi everyone,
Before I list everything that I've done to try to get the idle less rough, let me describe the situation as specifically as possible.
*Abnormally-rough warm idle to where the entire car shakes (rather violently) in gear, less rough out of gear, and smoothes-out beautifully when idle is slightly raised. Outside of the idle issue, the throttle response is phenomenal, and it runs like a top. It just acts like a milkshake machine at idle.*
I've done the following:
  1. Replaced points, condenser, plugs, wires, cap, rotor, air/fuel filters, set initial timing @ 7, & set dwell @ 32.
  2. Carb. rebuilt.
  3. Intake gasket replaced.
  4. All vacuum hoses replaced.
I thought that maybe a previous owner may've put a lumpier cam in, but I have a pro-gas 468 Olds with a 542/560 hydraulic flat-tappet with a 286/292 duration on a 112 lobe, and it didn't shake as violently as this Rallye does. Furthermore, a radical cam wouldn't necessarily make a car violently shake as the cam characteristics eminate from the exhaust, not the engine. Since the exhaust is bolted to the car with rubbber hangers, and the engoine secured more-directly with motor mounts, wouldn't the car would be much less-susceptible to the effects of a hefty cam, and more responsive to an engine malfunction/misfire, perhaps?
I'm going to do a compression test next, but my only other thought is whether a leaky exhaust system would cause this rough idle? Almost half the exhaust is escaping before the muffler, and the mufflers themselves have holes in them. I tried the dollar-bill trick at the tailpipe, but I don't think enough exhaust is coming out to determine if I have a burnt valve; if that would be a contributor to such a violent idle.
Also, maybe it's fickle crack in the intake or near a vacuum source?
I look forward to whatever any of you can suggest; as this car is an 86k survivor, and a blast to drive, I just can't keep a topless can of pop in the car...
-Christian
Old Apr 5, 2013 | 11:40 AM
DoubleV's Avatar
Did your engine run like this before the tuneup? It could be numerous things but I would check the idle mixture screws and check for vacuum leaks first. Got a vacuum gauge? If so, what's it pulling?
Old Apr 5, 2013 | 12:02 PM
boese1978's Avatar
Maybe
split motor mounts?
Old Apr 5, 2013 | 07:45 PM
DoubleV: Yes. Actually, it ran rougher before I did these things. I've already adjusted the mixture screws as well as identified all vacuum leaks (the biggest ones were around the intake, shich I replaced). I'll throw the vacuum gauge back on it tomorrow as post what I'm pulling.
boese1978: I did not check that. But that does raise a question; I thought that split motor mounts would only cause the motor itself to abnormally shake, and not the entire car...
Old Apr 5, 2013 | 07:54 PM
I'm going to suggest setting your dwell at 30, bump your timing to 10 maybe more if it will take it. Then reset your A/F and idle to it's liking.
Aug 22, 2019 08:45 AM
ronbo97
Jun 29, 2015 10:14 AM
1971olds350
Apr 29, 2009 08:59 PM
novice57
Jun 3, 2008 04:35 AM
UCF72Cutlass
May 31, 2008 07:09 PM
