Rally 350 engine specs??
Old Mar 25, 2018 | 01:26 PM
Kyle's77cutlass's Avatar
Looking at buying a 75 Omega for my son.
My son is turning 16 this year and am thinking would be a perfect car for him for his birthday.
Car is in awesome shape but have stuck a 305 Chubby engine in it. So I have a spare 76 olds 350 i can rebuild and put it in. But like any father would do, more power!!!Lol
Looking to build the engine to specs of the 350 rally.
Numbers be awesome
Thanks guys
Old Mar 25, 2018 | 02:44 PM
jensenracing77's Avatar
A Rallye 350 engine is just a 4 bbl 310 HP engine. Nothing special. I would just build it with 10:1 compression with good pistons and a roller cam that cutlassefi would recommend for your goals...
Old Mar 25, 2018 | 06:37 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Go for more like 9 to 1 compression, so he can run 87 octane. I run 9 to 1 with a 214/214 custom cam from Cutlassefi. I would get a converter as well, the Jeggs 2000 to 2300 stall has good reviews and is cheap. I went from a 2300 flash stall in my 2004R to the stock stall in a TH350C. It went from a tire burner to it won't even spin the tires. Of course the 2.78 gears don't help, your Omega will have similar gearing.
Old Mar 26, 2018 | 07:17 AM
In fact, the engine in the Rallye 350 was just the L74 motor, which was the base engine in the Cutlass Supreme that year.
Old Mar 26, 2018 | 11:39 AM
oldsmobiledave's Avatar
Why run 87 Octane? All 87 & 89 Octane fuels in Alberta & BC contain Ethanol. Why not build an engine to run on Ethanol free 91 or the 93/94 Octane Ethanol fuel that is available at most pumps? I know those fuel cost more... I am looking for other reasons. Compression makes power. I have no issues running my iron head engines with true 10:1 on the pump 93/94 or my Aluminum headed 11.2:1 engines on the same.
Old Mar 26, 2018 | 04:40 PM
I only run 91 octane, same rule here as well, premium is non ethanol. My next motor will be 9.6 to 1, I wouldn't push 10 to 1 with 91. There is no 93/94 locally that I know of. But this is for a 16 year old kid and some states have ethanol across the board and he may not look or care what goes in the car.
Old Mar 26, 2018 | 05:18 PM
GEARMAN69's Avatar
stroker kit and aluminum heads
Old Mar 26, 2018 | 06:15 PM
Has a different cam in them and #6 heads
Old Mar 26, 2018 | 06:18 PM
The car has a th350 in it already. So that a bonus.
Not what was done to fit a 305 Chubby in it tho.
Gears I would change out, mid 3 I think.
Cause of course dad needs to drive it too. Lol
Old Mar 26, 2018 | 06:21 PM
All 70 350's had 6 heads and all the 4 bbl 70 350 engines had the same cam other than the W-31. All 4bbl engines even had the same distributor including the W-31. You will be best off by going to a more modern cam for the same money.
Old Mar 26, 2018 | 06:22 PM
10:1 I like. Deck the block and shave the heads.
maybe flat tops in it.
Going to use iron heads on it. I have a set of 7s but also found a 1970 350 with 6 heads.
More compression, better burn.
Old Mar 26, 2018 | 06:24 PM
Yes was just looking for a comparable cam to the rally 350
Old Mar 26, 2018 | 06:27 PM
Oh yes. I think we have 91 at most. But I can get my hands on aviation fuel. Lol
So maybe tune down mid 9's then
Old Mar 26, 2018 | 06:30 PM
No stroker kit for my boys car.
That for my ride. Lol
When comes to heads, I am stuck to old school with heads.
I would spend the extra to port and polish the iron, just don't care for look of aluminum
Old Mar 26, 2018 | 06:37 PM
Old Mar 26, 2018 | 06:39 PM
Looking at it on Friday.
looks in good shape for 42 years old.
visual will decide tho
Old Mar 26, 2018 | 06:45 PM
The pictures look really nice. Hope it turns out to be a good one for you.
Old Mar 26, 2018 | 06:58 PM
Yes looks like a beauty
Old Mar 27, 2018 | 05:51 AM
Nice Omega. I leaned on the carb on my 70 on purpose so my daughter and her boyfriend wouldn't have as much fun with my 70S. I would go mid 9's with 91, you definitely want a better cam than the under 200 duration .400/.402 stock cam that came in the automatic Ralleye 350's. The standard trans cam was better but still not radical something like 210/210 .472/.472 I believe. Get the new Mahle 10cc dish pistons that Cutlassefi brought to the market, it will give you low to mid 9's for compression and get a cam from him as well.
Old Mar 27, 2018 | 12:39 PM
As stated above, that is a pathetic cam for performance.
.400"/.400" lift, 186º/202º duration @ .050" lift, 250º/264º advertised duration
Get a generic "RV" cam and it will be much better than the factory 350-4bbl cam.
Old Mar 27, 2018 | 05:15 PM
Okay cool beans. I will contact Mark once more. Lol
Old Mar 27, 2018 | 06:29 PM
1970greensupreme's Avatar
If your building to a ralley 350 spec the 4spd qb engines were standard if you have 3:42 and higher gears with a bit hotter cam. I think they used a 68-69 400 cam in those
Old Mar 28, 2018 | 06:51 PM
Okay. Thanks for the input guys
FStanley
Apr 8, 2016 01:55 PM
costpenn
Dec 28, 2013 08:39 AM
chris83
Sep 30, 2010 11:34 AM
xerxes600rr
Dec 22, 2009 05:41 AM
Big Dave
Dec 15, 2005 12:02 PM
