Radiator Hose collapsing flat
Old Mar 23, 2011 | 06:31 AM
OldsManNJ's Avatar
1971 Cutlass S
Hi all - weird issue...
71 cutlass with 350 -
When the engine is cold - the TOP radiator hose collapses flat when I start the car. It eventually inflates to normal as the engine heats up, but I am concerned I may have a bad thermostat, water pump, etc, and may overheat the engine and do some damage.
The bottom hose is fine at all times as far as I know.
The top hose is a little soft, but I don't think it is just the hose, as it is new. I remember from my youth that radiator hoses used to have springs inside them to stop the collapsing, and I did do some Google research on this. Most posts said that normally the bottom hose is the one with the spring inside it and that is the one that collapses - I could not find any posts about the top hose collapsing like this.
Any ideas what I should be looking for to resolve this issue?
Thanks to all of you who may respond to this - I do appreciate your time.
Old Mar 23, 2011 | 06:56 AM
Coolant flow in the Olds motors (and most other engines) is out the top hose, into the radiator, and into the water pump from the bottom hose. When the t-stat is closed, the water pump can create a lower pressure in the radiator, which can collapse the top hose. This may be indicating a bad t-stat, or it may be a weak hose. The fact that it returns to normal shape when the engine is warm tells me that the t-stat is opening, but it may not be opening all the way. You MIGHTASWELL replace both the hose and the t-stat as preventative maintenance.
Old Mar 23, 2011 | 07:12 AM
jag1886's Avatar
I'd say it's a old hose, new hoses are lot more ridged than the older hoses, I put a new lower hose on my car and noticed it didn't come with a spring inside like they used to, I emailed the manufacturer and they told me because of the newer materials the hoses don't need them anymore. If a bottom hose won't collapse then neither should the top hose.
Old Mar 23, 2011 | 08:47 AM
Lady72nRob71's Avatar
If the hose is not excessively soft, then it sounds like the radiator cap is not allowing air into the system as it cools - instead it is causing a big vacuum.
If the cap is slowly removed when cold, air should enter and the hose expands again.
You might need a new rad cap. Does this car have a coolant bottle? If so, it requires a special kind of cap.
Sampson
Mar 24, 2015 09:33 AM
jdanieljones
Dec 28, 2008 01:55 PM
Iragh
Nov 17, 2008 01:23 PM
njot33
Feb 25, 2008 08:18 AM
harleyrules
Nov 25, 2007 07:22 PM
