radiator & heater hoses
Old May 10, 2009 | 06:11 AM
65cutty's Avatar
being I dont have the car near by so as I cant measure the upper and lower radiator hose size. is the upper is 1 1/2 inch both ends? and the lower also 1 1/2 both ends and are both heater hoses 3/4 or 5/8 ? its a olds 350 1975 no air just heat thank you.......jim
Old May 31, 2009 | 11:09 AM
Joeypete's Avatar
I looked up the stock part and it says the upper is 1 9/16" on both ends and the lower is 1 9/16" on one end and 1 13/16" on the other.
Old May 31, 2009 | 11:51 AM
Texascarnut's Avatar
Geezer
Best bet is to measure both radiator connecting points as well as the thermostat housing and water pump inlet with a vernier caliper. Most applications are 1-1/2" both ends on upper radiator hose and the same with lower, but some show to have 1-3/4" on one end whether upper or lower.
Heater hoses are 1/2" in, 3/4" out except for an apparently oddball arrangement which had .63 both in and out. Check engine, pump, and core nipples with vernier caliper for correct size just to make sure.
Old Jun 1, 2009 | 05:57 PM
88 coupe's Avatar
Junior Member
Originally Posted by Texascarnut
........ measure both radiator connecting points as well as the thermostat housing and water pump inlet with a vernier caliper ........
Hoses and nipples are not machined surfaces that are measured in thousandths of an inch. Since those dimensions can easily be checked with a yardstick, verniers would not be necessary.
........ except for an apparently oddball arrangement which had .63 ........
.630" is suspiciously close to .625" (⅝") which is among the standard heater hose sizes.
........ Check engine, pump, and core nipples with vernier caliper for correct size just to make sure.
From the opening post:
being I dont have the car near by so as I cant measure the upper and lower radiator hose size .........
He cannot measure anything (with or without verniers) because the car is not where he is.
Norm
Old Jun 12, 2009 | 06:45 AM
65cutty's Avatar
thank you all for the great info...jim
John1963
Apr 29, 2012 02:15 PM
cargo442
Aug 31, 2011 06:11 PM
Del70
Oct 8, 2010 09:21 AM
mmurphy77
Jun 2, 2010 07:43 AM
Texas442
Nov 27, 2009 05:01 PM
