Quick Visual Quiz for the Less-Experienced
Old April 28th, 2014, 06:45 PM
  #41
Nope - it's a 350 and they didn't have the stamped sheet metal baffle in the bottom of the lifter valley, like the 425s, 455s, and early 330s did.
The thing I'm looking at is a sign that the engine was abused by someone in the past, but it doesn't affect how it runs now.
MDchanic is offline
Old April 28th, 2014, 06:48 PM
  #42
How about lack of oil changes and gunk in the valley
Allan R is offline
Old April 28th, 2014, 06:52 PM
  #43
Tree Row Hunter in N.D.
barnfind's Avatar
Might be a reflection but hole #2 (furthest right) looks cracked, scored
barnfind is offline
Old April 28th, 2014, 07:04 PM
  #44
Nope. With 106,000 miles on it, it's bound to be a bit black, and the ZDDP cam break-in additive is black, too, so that makes it worse.
There's actually no real gunk in there at all.
Yeah, darned reflections. I just couldn't get rid of them.
MDchanic is offline
Old April 28th, 2014, 07:10 PM
  #45
Magna86's Avatar
Ok every piston looks like it has the same 2 marks near the top of the dish ring. Maybe contact from valve float/valve-piston contact due to high revving fun? This is actually fun and would be great we had these quizzes more often. :-)
Magna86 is offline
Old April 28th, 2014, 07:11 PM
  #46
The rear intake seal let go and someone tried to fix it by stuffing it full of RTV?
Allan R is offline
Old April 28th, 2014, 07:24 PM
  #47
Nope.
It was sealed with RTV, but nothing unusual.
Hey, you can't win twice.
Yes, OEM Oldsmobile pistons don't have valve reliefs.
At some point in this engine's life, every valve hit a piston, which means it was pretty well overrevved, but not for too long, as the top end is original and the bearings looked fine for their age.
I don't have a picture of #8 because it was too far in the corner.
Great work, everyone, and Magna, I don't know if you'll be allowed to raise your hand any more...
MDchanic is offline
Old April 28th, 2014, 07:30 PM
  #48
Magna86's Avatar
I still have remembered things from high school auto class! haha To think I gave up being an auto mechanic and now have a desk job. Can we for 3 in a row i never win anything.
Magna86 is offline
Old April 28th, 2014, 07:33 PM
  #49
I'll have to see what screwed up thing I can find next.
MDchanic is offline
Old April 28th, 2014, 09:04 PM
  #50
Eric & Magna - 2
Us Dufuses - 0
So is this what you mean by pistons with valve relief?
Allan R is offline
Old April 28th, 2014, 09:43 PM
  #51
Phantom Phixer
Charlie Jones's Avatar
It kinda looks like the piston on the far left has some small "dings" in it . As though a piece of a broken spark plug hit it.
Charlie Jones is online now
Old April 29th, 2014, 02:43 AM
  #52
Yup. The factory never made ones like that, so any resemblance is purely the result of over-revving.
Yeah. I think you mean the #6 piston. I think it's some damage from detonation, but a very small piece of metal at some point is not out of the question.
MDchanic is offline
Old April 29th, 2014, 04:41 AM
  #53
Engine Builder
Smitty275's Avatar
I think you all have missed the real issue with the engine pictured. It is not of enough cubic inches and should immediately be replaced with an engine of no less than 105 cubic inches more.
Smitty275 is offline
Old April 29th, 2014, 05:20 PM
  #54
Macadoo's Avatar
The pistons hit the valves? Darnitt, too late again!
Macadoo is offline
Old April 29th, 2014, 05:53 PM
  #55
Lars's Avatar
more carbin buildup in #8 where the bad valve was and select fit pistons
Lars is offline
Old April 29th, 2014, 06:06 PM
  #56
Senior Moment Member
z11375ss's Avatar
Originally Posted by jaunty75
Ooh, ooh, I know, I know, I know, call on me, call on me, call on me!
It's upside down. It's supposed to look like this:
lmao!!!!
z11375ss is offline
Old May 1st, 2014, 11:55 AM
  #57
Seff's Avatar
I see valve marks on the pistons. On 2 and 4 the bigger intake is on the right (making the mark further north on the piston, on 6 and 8 they are on the left, so that fits.
The mark is visible just on the edge of the piston dish, at 10 and 0130 o'clock.
Tentative conclusion: Someone's timing chain slipped. (I should know, I did something similar to an engine once.... >.> )
EDIT: I didn't see page 2. Oops.
Seff is offline
Old May 1st, 2014, 12:54 PM
  #58
steverw's Avatar
Looks kinda like some heli coils put in some of the head bolt holes? Ooops i missed page two to
steverw is offline
Old May 1st, 2014, 08:14 PM
  #59
Quite possibly. It had a loose, low-end replacement timing set on it when I got it.
Actually, no. The heads had never been off, so those are the factory original holes and threads.
MDchanic is offline
Old May 2nd, 2014, 04:30 PM
  #60
M-14's Avatar
Olds engines have valve angles about 6 degrees to the piston, so it take a lot of valve float (hi rpms)on a stock engine to make them kiss the piston. Sbc have an angle at 23 degrees, they need valve reliefs in theirs hi-po pistons. Most engines with 4 valves per cylinder have valve angles of 35 degrees of higher. That's why you hear about bent valves when timing belts or chains break. Olds engines usually don't have bent valves when the chain breaks or jumps. That's the best engine cutaway I could find for the olds, you can see the chevy in the 2nd picture has more of an angles, & the buick nail head has a big valve angle. Look at the exhaust passage, it looks extremely restrictive.
M-14 is offline
Old May 2nd, 2014, 07:58 PM
  #61
Good information. Thanks!
I hadn't realized that the nailhead rockers worked "backwards."
I'd also just been wondering what the Olds valve angle is, as I need to make a valve stem height gauge, so thanks for answering the question I was thinking about asking!
MDchanic is offline
Old May 3rd, 2014, 05:11 AM
  #62
M-14's Avatar
Yeah, the designers were really thinking out of the box on the nail head.
I've heard that the olds angle is around 6-7 degrees, so my info isn't a precise measurement (taken with a grain of salt).
M-14 is offline
MDchanic
February 25th, 2014 11:42 PM
Rocketguy
February 25th, 2014 04:23 AM
My442
February 16th, 2013 04:08 PM
MDchanic
August 16th, 2012 07:38 AM
oldjunkster
September 1st, 2010 05:45 AM
Quick Reply: Quick Visual Quiz for the Less-Experienced
