Quadrajet running rich, need help
Rocket "Scientist"
So, my car originally (VIN L) had a 350 Chevy, with a 4bbl, that was swapped at 81k miles for whatever reason in 1993, engine has less than 100k miles on it now, but the carb is running rich.
For the record, I know it does not need plugs or wires, it is not running rough, it idles smooth, accelerates smooth, comes off WOT smooth, everything is smooth, once you get up to speed you can't even tell it's running rich. It's only really noticeable at idle, and it runs even richer the colder it gets. Once it warms up it doesn't seem to run rich at all.
It has the stock intake, possibly the stock Q-jet too, but it has an aftermarket choke control that pushes in, rather than being pulled out. I plan to add an Edelbrock 4bbl 1406 carb, and an Edelbrock 2701 performer EPS intake when I can afford it, but that is many paychecks away, so I need a stop gap solution for the rich running Q-jet.
Is it possible I can just use the adjustment screws and make it run leaner? Or do something else simple like that? Thanks for any advice you can give.
Rocket "Scientist"
I don't know any specs on the engine other than that the crate engine was rated at around 195HP, versus the 170 stock for the SBC that was in the car, if that matters.
Rocket "Scientist"
I guess to further clarify what I mean by "rich", there is a strong smell of unburnt gasoline present when the car is idling, and the colder it gets, the worse it gets.
What do the spark plugs look like ? I doubt a 600 cfm carb would be rich . It can be rich at idle but I have had 600,650,750, even an 835 cfm and they all worked pretty great . The 600 was used on a mild mild near stock build and it was great. I had a head gasket leak that was very minor but it sat over winter and eventually the cylinders got a little pool going in there.
Rocket "Scientist"
Found out the carburetor had just been ate up with ethanol, I got another one which had been improperly rebuilt, then got a Summit racing 600 or 650, forgot which, didn't like it that much, got a Holley 750, it's kinda messed up too, I can't win for losing.
Just so ya' know, and also I'm probably going to look into a summit 750CFM "Performance" q-jet, I like the way the Q-jet's run when they're right.
Likely, one of these:
http://www.summitracing.com/parts/sum-210202/overview/
derek nesdoly
November 18th, 2009 04:50 AM
