Quadrajet 73 vs 73
Quadrajet 73 vs 73
I am swapping out my 2bbl on my 1969 cutlass 350 for a 4bbl. The 4bbl I have according to the numbers is a 1973 quadrajet. What are the differences between a 73 and a 69 quadrajet, and will it work? I know it has an electric choke and I suspect it has more vacuum lines.
This probably isn't even true so don't quote me 69 at least to me had all the good things carwize so imo 69 is netter. Now on the other hand as far as more vacuum lines thryccsn always be plugged up not a problem there
GM cars used EGR starting in 1973. EGR injects exhaust gasses (up to about 15% by volume, depending on conditions) into the intake.
EGR is designed as an element in reducing exhaust emissions.
In 1973, the regulated exhaust gas components were CO, NOx, and hydrocarbons (as well as lead and evaporation), if I am not mistaken.
The leaner you run an engine, the less CO and hydrocarbons you will produce, but running an engine lean will increase combustion temperatures, which will tend to produce oxides of nitrogen (NOx).
In order to be able to run lean, thus reducing CO and hydrocarbons, but not create extra NOx, two things were done:
One was to reduce compression ratios, as increased compression increases combustion chamber temperatures.
The other was to introduce EGR.
By adding an inert gas (exhaust gas, which has already been burned) into the mixture, the mixture was cooled slightly, and NOx were reduced.
The EGR doesn't affect the mixture itself (being inert), but displaces the oxygen and fuel, in essence reducing the compression ratio or the displacement of the engine (depending on how you look at it).
Because EGR is used to allow leaner mixtures, the carburetors used with EGR are jetted leaner, and, in fact, may be jetted lean enough that they could cause some detonation under hot conditions if used without EGR.
Also, since Emission testing at the time was done at idle and cruising only, most of these carburetors have power valves that kick in at relatively high vacuum levels (slight throttle openings), enriching the mixture more than you necessarily need when you step on the gas.
While all of these things can be modified, it would seem easier to just use an earlier carburetor that was designed for use without EGR, as they are neither hard to come by nor expensive.
Oh dear, I seem to have infected you with a case of the smileys. D:
But, that sets my mind at ease. And gives me ammo for when the environmentally conscious people give me crap for driving an old, smelly car.
Pardon the thread derailment.
