pulley measurement
Old Jun 20, 2007 | 10:21 AM
retrorocket87's Avatar
pulley measurement
How do you measure pulley diameter? On v-belt pulleys do you measure the outside diameter, the inside diameter or the pitch diameter? On a serpentine pulley do you measure the outside diameter, the bottom of the grooves or the high points (tops) of the grooves? On v-belt and serpentine belt charts they list two lengths. One is the effective length and the other is the outside length. If for example you measured over several pulleys to determine belt length would this measurement be the effective length or the outside length? I need a quick tutorial from someone in the know. Thanks
midrange
May 7, 2012 12:31 PM
RAMBOW
Jul 27, 2011 05:35 PM
montvaleplace
Apr 8, 2011 01:52 PM
Bluevista
Feb 13, 2011 03:00 PM
65az
Mar 24, 2009 09:20 PM
