popping through the carb
Old Oct 21, 2010 | 06:57 AM
fiona72's Avatar
Hello,
Thanks for any input you can give... I have a 72 Cutlass with a 1978 350 rocket in it. I have had it over at the shop recently and had the carb rebuilt, new gas tank and a tune up... Why is it still popping through the carb under heavy acceleration?
Thanks,
Greg
Old Oct 21, 2010 | 07:10 AM
Lady72nRob71's Avatar
Does it hesitate (like it is wanting to die) then pop? If so it sounds like it is runnin too lean. Was it checked for vacuum leaks? Was the timing set right?
Did the carb guy adjust it all right including the accellerator pump?
Since it is a 78 motor, I assume the carb was rebuilt to 78 specs. Is the EGR valve working right, or stuck? They have a tendency to clog up and jamb open or closed.
Just some first thoughts...
Old Oct 21, 2010 | 08:04 AM
Was it popping prior to all the work you just had done??
Old Oct 21, 2010 | 08:14 AM
70 cutlass s's Avatar
Was the plug wires replaced when it had a tune up?
Old Oct 21, 2010 | 07:52 PM
MN71W30's Avatar
Could be a broken intake valve spring. Is it ticking?
Old Oct 21, 2010 | 07:54 PM
stan 65 cutlass's Avatar
burnt valve?
Old Oct 22, 2010 | 04:46 AM
oldsfever's Avatar
I had one do that when a lobe on the cam was worn down.
Old Oct 22, 2010 | 05:50 AM
MN71W30's Avatar
Originally Posted by oldsfever
i had one do that when a lobe on the cam was worn down.
x2
Old Oct 22, 2010 | 07:10 AM
citcapp's Avatar
Two of the plug wires out of sequence at the distributor. check it out
Old Oct 22, 2010 | 09:53 AM
fiona72's Avatar
Thanks guys,
The car was popping before the work was completed; it seems to do it more when cold. It does run better after the work was done as far as initial start up and idling. My mechanic (who is a gear head) suggested possibly a flat cam or something in the valve train as well.
I plan on rebuilding the motor this winter or finding a suitable replacement, just wanted to get the car on the road to see what else may be wrong. I drove the car home from the shop (approx 20 miles) and handles great, so I need to pay attention to the motor. Any other suggestions please feel free to add on.
Thanks again,
Greg
Old Oct 22, 2010 | 12:02 PM
Boh2k's Avatar
Originally Posted by mn71w30
x2
x3
Old Oct 24, 2010 | 08:25 AM
Warhead's Avatar
Check your carburetor's accelerator pump/ pump shot first.
No matter which carb, look down the throat, hit the throttle, and you should see 2 nice streams of gas going down into the manifold. If not, make it do so.
That is the first thing I look for, before I'd go to the other items mentioned on this thread, although Rob Young did mention it.
Backfire through the carb is a lean pop. When you hit the gas, you need FUEL, and a bunch of it.
Carb accelerator pump, goes a long way here.
Carb rebuild is NOT part of a tune-up.
JMO
Jim
Old Oct 25, 2010 | 06:28 PM
fiona72's Avatar
Thanks Warhead,
I actually did the tune up myself and had the shop do the rest (due to their lift and carb boil tank capability). They replaced the accelerator pump when completing the carb rebuild, but I will check what you recommended. When I pulled the fuel filter there was allot of gunk on it and found some buildup in the tank, and that is why I replaced everything from A to Z to eliminate that problem. I will keep you posted regardless.
Thanks,
Greg
budworks521
Jul 2, 2014 04:02 AM
cfair
Nov 17, 2012 10:50 AM
at3reg98
Jun 21, 2012 05:06 PM
jpc647
Nov 19, 2011 02:13 AM
fiona72
Oct 28, 2010 01:05 AM
