Piston recommendation for higher compression
I'm in the process of rebuilding my '72 350, will be reboring 30 over and wanted to go with a smaller dish piston to boost my compression high enough to run regular octane while increasing performance. Any spec/manuf suggestions?
...also have a XE262H, heads are done (3 angle etc...)
I found a cast iron piston from Mondello 11.9cc with 7a heads should be 9:14:1...is this regular octane friendly?
http://www.mondellotwister.com/PisPinRingBrng.htm
9.14 is pump gas friendly.
Imo you can do better for not a lot more money
http://webcache.googleusercontent.co...istons&ct=clnk
Use a moly ring if possible, not that much more.
Jmo.
Btw 89 octane, maybe, depending on the cam and gear.
I'm looking at a TRW piston set (NOS) with the following specs;
TRW L 2389F .040 OVERSIZE FORGED PISTONS AND ONE SET OF TRW T 8190X OVERSIZE CAST PISTON RINGS
2.932" X .235" DEEP CUP,1.610" COMPRESSION DISTANCE AND A .980" DIAMETER PIN.RINGLANDS ARE FOR 5/64",5/64",3/16" RINGS
Are these slightly higher compression than stock (stock 2.920/0.215 dish and compression distance is 1.595)?
.040 is mentioned is this non standard (.030)?
Thanks for all the advice
I'm not sure if the larger compression distance (between wrist center and piston top) would bring it closer to the head giving more compression. It looks to be a pretty low compression piston in any case...
Last edited by MDchanic; April 22nd, 2011 at 01:41 PM. Reason: Recalculated for 0.040" additional piston diameter.
dirtydynamic
December 27th, 2011 08:34 AM
