Pinging at low rpm
Old Jun 16, 2020 | 06:49 PM
Orlando 1's Avatar
O'smobile
Pinging at low rpm
I'm having a similar issue with my 68. Pings at low rpm. All parts are from 68 and 69 Olds 350 engines unless otherwise indicated.
What was done:
-350 .030 over
-forged flat top pistons
-w31 spec cam from Lunati (308 dur, 474 lift)
-64 cc #5 heads with mild porting to relieve the larger valve (2" int, 1.65" exh)
-HEI from 1977 Cutlass 350 (plugs gapped to 60)
-Holley 625 cfm spreadbore
-Hooker long tube headers (1-5/8" primaries)
Next:
  1. turn distributor counterclockwise 15 degrees to retard; test drive
  2. install octane boost; test drive
Considering:
  • install original points distributor (not sure what the weights and springs should be for w31 spec)
  • install original 750 4mv I rebuilt with the w31 spec rods and jets (problem here and why I didn't start with this carb, top piece is warped a bit. I finished the rebuild but not sure of it's integrity).
  • locate a new 750 cfm 4MV and install the w31 rods and jets
Old Jun 17, 2020 | 04:07 PM
I moved your post to its own thread, its hard to work on 2 different cars in the same thread.
Old Jun 17, 2020 | 05:02 PM
cutlassefi's Avatar
Did you use or buy a wideband O2 to make sure the carb is jetted right? I’m going to go out on a limb and say no.
Old Jun 18, 2020 | 12:04 AM
dragline's Avatar
What is your initial and total timing with vacuum advance disconnected? What is the estimated compression ratio? Distributor may need to be recurved for your engine.
Old Jun 19, 2020 | 05:31 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would bet you have over 50 degrees part throttle, maybe even close to 60. I would start with an adjustable vacuum advance canister turned down to 10 degrees. The stock 77 vacuum canister will be 25 to 30 degrees. As Mark said, if you carb wasn't adjusted with a wideband, it could be way out to lunch.
Old Jun 25, 2020 | 07:48 PM
Orlando 1's Avatar
O'smobile
Thanks for all the feedback. Retarding timing helped the ping issue. I'm going to work on the vacuum and mechanical advance next. I think my vacuum advance is a non-factory advance that is adjustable.
  • Regarding jets, are they changed during the curving process or are these separate?
  • Are there any special tools needed to curve a distributor? How was it done back in 1968?
jensenracing77
May 22, 2018 06:30 PM
Oldzman71
Feb 20, 2018 03:10 AM
camshaw
Jul 12, 2014 09:20 AM
GoldOlds
May 18, 2007 10:13 AM
