Performer rpm cam/valve spring question
Hey folks, need some help here. I purchased the performer rpm cam 7112, performer rpm Intake 7111, performer link timing set 7813 for a olds 350 build. After purchasing the parts required I noticed there is one part i need that now seems to be discontinued. The valve springs I need (part number 5712) I can not find anywhere. Anyone know if I can use another set of valve springs for that cam? Or would anyone have a set on a shelf they'd sell?
I do not know the actual height at the moment. it's a 73 block, I've got #5 heads to rebuild, plus the performer rpm kit to install with retainers and locks for the edelbrock sure seat 5712 valve springs, the only piece to this puzzle I don't have is the valve springs. I can get the springs for aluminum heads but the ones for cast iron heads are discontinued. This was just a project to slap together and see what happens. Cam , timing kit and intake were givin to me, Engine was something I had stored. I only had to buy the heads and parts to rebuild the heads for that cam/intake. But those springs are awful hard to find. as for rear ratio I'm unsure, spider gears and center pin blew up so was planning rear end rebuild after I rebuild the motor. It's a 69 cutlass retired pro drag car from the 80s that I'm restoring just enough to get back on the road and enjoy it.
#1. Measure the valve spring installed height to determine what you have.
#2. Then contact Cutlassefi for valve springs for your application.
There is nothing "magical" or special about the Edelbrock valve springs. Have the valve spring pockets been machined deeper for a taller valve spring ? Do you have a valve spring tester ?
those are questions I can't answer as don't have the springs to Install and take measurements. Can't find much info other than what Summit has listed.
76Supreme350
February 25th, 2023 11:43 AM
