performer olds 350 intake with holley 4160
Was just wondering if anyone was running a holley 4160/4150 on their performer olds 350 intake w/o spacer or adapter?
For some reason I thought I didn't run a spacer on my last build ( over 10 years ago ).
On my current car (70 cutlass) the fuel line has clearance issues with manifold basically doesn't work without installing spacer in conjunction.
Good to hear i'm not the only one, the adapter i used was a quadrajet to square adapter , what about you? Looking at edlebrocks website it shows this manifold designed for stock carb. ( didn't see that initially )
I had the same problem on my recent build. I put the performer intake on and initially tried to put the 1406 edelbrock carb on it and there was no way it was going to fit. In fact, I had to put a piece of 2x4 under it before it looked like the linkage was going to fit.
I tried a holley 80457SA 600cfm single feed carb and it almost worked out the gate. It needed just a little spacer... so I picked up a 1/2" or 3/4" spacer and it cleared great. The holley linkage adapter fit perfect.
Car started first time and ran beautifully with that carb and intake combination.
-Dan
-Dan
arodenhiser
November 30th, 2012 06:25 AM
fast67vellen2o
October 24th, 2010 06:11 PM
