overheating 1987 cutlass supreme
I have a 1987 cutlass I've have for about 3 years haven't drove it in about 2 years I finally pulled it out of gramps garage and it started having overheating issues I changed the thermostat and now I can't screw the 2 bolts back in like there's not enough thread or somthing anyone have and suggestions and there is some really dark brown stuff in my radiator looks almost like dark brown mud need help asap
Thank u
Cane.
Thank u
Cane.
Welcome to C.O.! What do the threads look like on the intake and the bolts? Pictures of hardware would help.
Get some radiator flush products, try flushing radiator and system with fresh water several times.
Pat
Pat
+1. You didn't happen to have plain water in it, did you?
See how it goes after a really good flush with the proper flushing substance and lots of water.
It would be best to remove the 3 or 4 water jacket plugs from the block, as well (located nearly behind the lower parts of the exhaust manifolds).
After all of that, you may need a radiator anyway.
Welcome to the site, I moved your post here to get additional views to your problem. The reason your bolts may not start is the threads may need to be chased with a tap. I always us a thread sealer on the bolts like plumbers pipe dope. I also recommend flushing your cooling system for starters.
jkoester122
December 10th, 2010 01:46 PM
jkoester122
December 7th, 2010 05:06 AM
jkoester122
December 6th, 2010 09:02 PM
69CuTlass S
September 19th, 2010 09:24 AM
