One easy question for my 5A 307
Old Oct 10, 2025 | 10:41 AM
chantecoq's Avatar
Hi
Why is it so difficult to find the information concerning the right spark plugs for my olds 307 (1980 with 5A head). There is no information in the service manual !
I looked at the forum, I found nothing very sure.
Can anyone confirm me which sparks I may use ?
Is it the R46SX ?
Thanks a lot that will help me a lot.
Old Oct 10, 2025 | 12:01 PM
The information is on the emissions sticker under the hood. Since there were variations for engine options and 49-state vs Calif, it was easier to just put it on the decal.
Old Oct 10, 2025 | 03:01 PM
69HO43's Avatar
You probably want R46SZ (GM p/n 5613882), which is the substitute GM recommended for the R46SX (GM p/n 5613881) circa 1986. The SX comes preset with an 0.080" gap, while the SZ comes with an 0.060" gap. This was due to the wide gap putting too much strain on the ignition module and causing early failures that GM had to fix under warranty. Shortening the gap seemed to fix the issue and still not hurt the performance.
You could always regap an SX, but that's up to you. Regardless, I'd ditch the 0.080" gap and go with 0.050-0.060" plus or minus.
Old Oct 11, 2025 | 05:23 AM
chantecoq's Avatar
Hi
Thank you so much for your help. The reason I could not get the info on the emission sticker is the engine is in a cadillac (swap).
I will buy a set of R46SZ.
All the best.
kevdog442
Oct 24, 2023 09:02 AM
carbonf00tprint
Nov 4, 2012 07:53 AM
easytobedead
Apr 17, 2010 06:51 PM
veltboy618
Mar 24, 2009 09:55 PM
