Oldsmobile 350 engine flywheel counterweight/balance question
Old Jan 31, 2025 | 05:25 PM
AozakiOlds's Avatar
GeneralMotorsfanaccount
Good evening.
I had a general question involving what I assume is the factory small block flywheel/flexplate. So, I have already fully re-installed the TH350 transmission in my 1970 Cutlass. Since it has been cold recently, I haven't worked on the car in over a week now. I was under it yesterday and was about to put the torque converter cover on, when I noticed something I had failed to see before on the flexplate. It appears that before I bought the car, someone had recently ground off a bit of the counterweight. I am not sure why, but I assume that at some point they had tried to install a Chevrolet-type torque converter with the larger mounting points for the torque converter bolts which overlap with this counterweight strip. My main question is, is this amount of lost metal a significant amount that would be enough to throw off the crankshaft balance and cause engine bearing or other damage? To be honest, I really do not want to have to take the transmission back out again, but if I have to, I will do if if this flexplate actually needs to be replaced.
I appreciate any advice over this.
Old Feb 1, 2025 | 05:45 AM
oldsmoboogie's Avatar
I would not think twice about running that the way it is.
Old Feb 1, 2025 | 06:27 AM
tru-blue 442's Avatar
Old School Olds
Agreed, run it.
Old Feb 1, 2025 | 08:48 AM
fleming442's Avatar
I wouldn't lose any sleep over it.
Old Feb 1, 2025 | 11:12 AM
AozakiOlds's Avatar
Agreed, run it.
Thanks!
Old Feb 1, 2025 | 11:13 AM
AozakiOlds's Avatar
Thank you!
Old Feb 1, 2025 | 11:15 AM
AozakiOlds's Avatar
Thanks!
8point
Apr 22, 2014 01:37 PM
71cutlass442
Oct 1, 2013 08:58 AM
Finn5033
Jun 16, 2012 12:59 PM
cbold68
Jan 15, 2012 06:22 PM
olds455
May 17, 2010 04:43 PM
