olds 5.7 L diesel
Old Dec 9, 2006 | 11:47 AM
al_gohi's Avatar
olds 5.7 L diesel
I´m from Spain.
I´ve a olds custom cruiser 5.7 L diesel.
I need a some technical data:
- cylinder heads bolt torque
- order for torque
Thanks.
Old Dec 17, 2006 | 01:54 PM
American Lead's Avatar
2Blue 55
What year is it?
Old Dec 17, 2006 | 11:21 PM
al_gohi's Avatar
It´s 1979. The block is "D".
Thanks.
Old Dec 18, 2006 | 01:07 PM
2Blue 55
Hello,
I couldnt find anything on a diesel rig, but i found the onesfor a normal, i dont imagine they would be much different, they are at the following site: http://members.tripod.com/torquespecs/oldsfs70-88.htm, but incase you cant get there :
Component Torque
Cylinder Head Bolts 350 cu. in. ( 1977 and later ) and 403 cu. in. 130 ft. lbs. *
All Others 85 ft. lbs. *
Driveplate Bolts ( Automatic ) 60 ft. lbs.
Exhaust Manifold Bolts 25 ft. lbs.
Flywheel Bolts ( Manual ) 90 ft. lbs.
Intake Manifold Bolts 40 ft. lbs. *
Main Bearing Cap Bolts Rear Main Cap ( #5 ) All 120 ft. lbs.
Caps #1 through #4 ( 455 ) 120 ft. lbs.
Caps #1 through #4 ( All others ) 80 ft. lbs.
Oil Pan Bolts 10 ft. lbs.
Oil Pan Nuts 17 ft. lbs.
Oil Pump Cover Screws 8 ft. lbs.
Rocker Arm Cover Bolts 7 ft. lbs.
Rocker Arm Pivot Bolts 25 ft. lbs.
Rod Bearing Cap Nuts 1970-86 42 ft. lbs.
1987 48 ft. lbs.
1988 Step 1 18 ft. lbs.
Step 2 Note 2
Thermostat Housing-to-Intake Manifold Bolts 20 ft. lbs.
Timing Chain Cover Bolts 35 ft. lbs.
Vibration Damper-to-Crankshaft Bolt 200-310 ft. lbs.
Water Pump-to-Engine Block Bolts 13 ft. lbs.
GM Full Size 1970-88
Transmission/Drive Train
Component Torque
Bell Housing-to-Engine Bolts 40 ft. lbs.
Differential Cover Bolts 20 ft. lbs.
Pinion Shaft Lock Bolt 25 ft. lbs.
Pressure Plate-to-Flywheel Bolts 25 ft. lbs.
Tail Cone-to-Transmission Bolts ( Manual ) 46 ft. lbs.
Torque Converter-to-Driveplate Bolts 1970-85 25-35 ft. lbs.
1986-88 46 ft. lbs.
Transmission-to-Bell Housing Bolts 55 ft. lbs.
Transmission-to-Engine Bolts ( Automatic ) 40 ft. lbs.
Transmission Crossmember-to-Frame Bolts 25 ft. lbs.
Transmission Mount-to-Transmission Bolts 30 ft. lbs.
Universal Joint Flange Bolts 70 ft. lbs.
Universal Joint Strap Bolts 15 ft. lbs.
Universal Joint U-bolt Nuts 15 ft. lbs.
Brakes
Component Torque
Brake Hose-to-Caliper Inlet Fitting Bolt 32 ft. lbs.
Caliper Mounting Bolts 37 ft. lbs.
Master Cylinder Mounting Nuts 24 ft. lbs.
Power Booster Mounting Nuts 24 ft. lbs.
Wheel Cylinder Mounting Bolts 13 ft. lbs.
Front Suspension
Component Torque
Front Shock Absorber Upper stud Nut 10 ft. lbs.
Front Shock Absorber-to-Lower Control Arm Bolts 20 ft. lbs.
Front Stabilizer Bar Bracket-to-Frame Bolts 25 ft. lbs.
Front Stabilizer Bar Link-to-Shaft Nut 15 ft. lbs.
Lower Balljoint Stud-to-Steering Knuckle Nut 80 ft. lbs.
Lower Control Arm-to-Frame Pivot Bolt/Nut 90 ft. lbs.
Upper Balljoint Stud-to-Steering Knuckle Nut 40 ft. lbs.
Upper Control Arm Nuts 80 ft. lbs.
Rear Suspension
Component Torque
Leaf Spring Anchor Plate Nuts 40 ft. lbs.
Leaf Spring Front Eye Nuts 75 ft. lbs.
Leaf Spring Rear Shackle Pin Nuts 95 ft. lbs.
Rear Control Arm Bolts/Nuts All Except Rear Upper 110 ft. lbs.
Rear Upper 80 ft. lbs.
Rear Shock Absorber-to-Lower Mount 65 ft. lbs.
Rear Shock Absorber-to-Upper Mount 15 ft. lbs.
Rear Stabilizer Bar-to-Lower Control Arm Nut 50 ft. lbs.
Rear Stabilizer Bar Insulator Bracket Nuts 30 ft. lbs.
Rear Stabilizer Bar Clamp Bolts 20 ft. lbs.
Steering
Component Torque
Idler Arm-to-Frame Nuts 40 ft. lbs.
Idler Arm-to-Intermediate Rod Nut 35 ft. lbs.
Intermediate Shaft Pinch Bolts 50 ft. lbs.
Pitman Arm-to-Intermediate Rod Nut 40 ft. lbs.
Pitman Arm-to-Pitman Shaft Nut 185 ft. lbs.
Steering Gear-to-Frame Bolts 70 ft. lbs.
Tie Rod Adjuster Sleeve Clamp Nut 20 ft. lbs.
Tie Rod End-to-Intermediate Rod Nut 50 ft. lbs.
Tie Rod End-to-Steering Knuckle Nut 30 ft. lbs.
more then you wanted, but here it is
Old Dec 18, 2006 | 02:24 PM
al_gohi's Avatar
Thank you very much.
88hurstolds
Aug 26, 2023 07:39 PM
kre
Jun 14, 2017 09:34 PM
88hurstolds
Aug 12, 2008 08:58 AM
71rocket
Dec 13, 2007 12:54 PM
1340
Apr 2, 2006 07:13 PM
