Olds 350 exhaust manifolds?
I'm picking up a set of exhaust manifolds that are being sold from a a 69 cutlass 350.
The passenger side looks like it has a large #4 stamped on the front runner along with a heat shield cover.
The drivers side has a #1 stamped on it with a black lever near the outlet. No center dividers either. Number on the drivers side are GWY 650001LH and D6 129.
Any help would be appreciated.
I have seen 350 manifolds fitted to 455,s before with a little work and yours sound like the pair i saw mounted. by the way after a little massaging these manifolds only cranked out 15 net less then doug thorley headers 1 and 3 qters. or 22 to 23 at the flywheel. think about it with a little work and hogging. by the way open exhaust about the same as headers corked up and cheaper. nice winter project.
OK, so your wanting to put these on a 455, correct? They will physically bolt up but the area inside the manifolds are significantly smaller on the small block vs. the big block. Here's a picture to compare/contrast them. The one with an X is the drivers side of a 1971 Olds 98 manifold. The number 1 is the drivers side of a 350 manifold like you've got.
John
John
