Olds 260 base timing
Old Jul 18, 2016 | 05:02 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I finally put a timing light on my 260 in the 70S. First off, it runs great. Decent mileage and power for a 260 with NO pinging. With the vacuum advanced unplugged, it was at 36 degrees at 1000 rpm. Around 700 rpm, 30 degrees. Thinking there might be another 30 degrees added with the vacuum advance. I did one light and medium spring, unless it is advancing a lot at low rpm, it is very advanced. If it is advancing that much, then it is different than any other factory HEI with lighter springs. I could never get full advance much under 3000 rpm.
Old Jul 18, 2016 | 06:16 PM
svnt442's Avatar
Odd. If I remember correctly it should be 20°@1100RPM.
Old Jul 18, 2016 | 09:55 PM
That is my understanding as well. This 260 has that crappy little balancer, doubt if it could spin. I am of the belief that the Olds V8 loves a lot timing, this 260 is more proof.
Old Jul 19, 2016 | 05:34 AM
distributorguy's Avatar
Yes they like a lot of timing. My 350 is set about the same. But, you shouldn't be advancing at such a low rpm. Timing should stay stable through fast idle, then advance above that.
JOHNNYOLDS442
Nov 18, 2015 11:54 AM
MDchanic
Sep 29, 2010 02:05 PM
OldsMotion
Sep 17, 2009 09:42 PM
442scotty
May 13, 2009 05:42 PM
Alkoh0liker
Jan 1, 2009 07:42 AM
