ol4b carb recommendations
Old Aug 20, 2006 | 08:15 PM
1BAD68"S"'s Avatar
okay so i scored an edelbrock ol4b intake that had a crack in the usual heat riser area...well its fixed and you cant even tell it was cracked...anyways i just blew up my big block on the dyno and i have to go with plan "b" and redo the small block. my question is what is the recommended 4bbl carb to top this vintage intake with??
Old Aug 21, 2006 | 10:42 AM
69deltaconvert's Avatar
Well if the intake is a spred bore I would put a Q-jet 650 cfm on it. I know they look scary and complicated but they work great and have about the best throtle response of any carb out there. If its a square bore go edelbrock or Carter AFB. If it has an exhaust crossover get the plugs for it from summit.
Old Aug 24, 2006 | 02:50 PM
1BAD68"S"'s Avatar
quadrajunk...
im staying away from quadrajunks...i hate them...i wanna say its a sqarebore and im looking at throwing a 750 double pump holly or a 750 squareflange edelbrock on it...not sure...as far as that exaust crossover(heat riser)...thats where the ol4b intakes like to crack and i had mine professionaly done and you cant even tell it was cracked...i mean if they can trust my step dad to weld things for f-22 raptors and the space shuttle then i guess trusting him with my 30 year old vintage intake was a no brainer...oh well...back to wrenchin on the hot rod thanks fer da advice.
Old Aug 24, 2006 | 07:41 PM
Dont forget the crossover block outs they rattle a little bit but they save the manifold and you dont have to weld up the crossover in the heads.
Redog
Apr 15, 2013 08:18 AM
OldsMotion
Oct 12, 2012 07:05 PM
Shradezz70S
Jul 28, 2012 10:01 AM
tnelson
Jun 28, 2010 11:36 AM
Wireman134
Sep 13, 2008 05:29 PM
