oil restrictors
oil restrictors
im using the mondello oil restrictors in the 3 main saddles of my 403. I did not however use locktight before i installed them. I also elongated the main bearing holes. DO i really need to worry about them falling out? The engine is already together.
The only danger is to your wallet for buying "restrictors" that don't really restrict anything...
Originally Posted by dman0712
........ Do I really need to worry about them falling out? ........
........ The absolute worst thing that could happen is that they slide down to the backside of the main bearing shells ........
Originally Posted by citcapp
........ What does Mondello have to say about this issue
Originally Posted by Joe Mondello
Main bearing oil holes should be enlarged to 17/64". Oil restrictors should be installed in the main bearing housing holes. Also, the fitting at the front of the block that squirts oil on the timing chain should be plugged.
Originally Posted by oldsonharmont
........ I take it you don't think the restrictors are a worth while expense ........
https://classicoldsmobile.com/forums...tml#post171389
Norm
Oil pressure will hold them in place.
Resulting in a restriction at his oversize hole in the bearing?
The oil is limited by the small hole in the restictor anyway
From the Mondello Technical Manual, Volume 1
He, and a lot of others.
Norm
Norm
To answer your question: You would have to remove the crank and bearings, in order to to gain access to the restrictors. If you used a hammer to install them, you will need a hammer to remove them.
To give you some advice: If you used a hammer to install them, they will not fall out.
Norm
Norm
do i just use a punch to push the restrictors down and out the cam bearing hole toward the top of the block or what? WIll my oversized holes in the main bearings be ok without the restrictors or should i get new bearings? I thought the restrictors help to keep more oil on the crank
Make sure the restrictor does not block other angled holes at the juncture.
The restrictor is only to hold back oil going straight up to the cam bearing.
I like the hole at the main bearing to be larger than the hole to the cam.
Many main bearings now available, do not match the oiling hole correctly in the block saddle.
This mis-match causes an oiling issue (restriction) at the main bearing. NOT GOOD.
Opening the main bearing hole only does good things for the crankshaft.
If you have already opened them up, leave them that way.
My opinion
Jim
ok because thats what i did. I opened up the hole enough so the entire cam hole was exposed but if i keep it that way i would like to remove the oil restrictor because if for some reason it does slide out the bearing shell will not stop it.
From my understanding with Joe Mondello restrictors process was not just putting restrictors in 2,3,4 mains is 1/2 of the job. For the bearings to benefit from the restrictors, the lower bearing shells Journals 2, 3 and 4 should be opened up with 5/16 drill, then elongated, toward the center of oil hole restrictor with regular round rat-tail file. End of groove must line up with center of restrictor hole.The Bearing will now receive full benefit of extra oil remaining downstairs, thanks to the restrictor plugs. This is according to The master of Oldsmobile engines. Joe Mondello himself.
