Oil pressure sending unit removal
Hi all
I am adding a rally pack gauge set up and need to remove the dummy light oil sending unit to install the proper one does anyone have any hints on how to get it out it seems pretty stuck in there and no great ways to get onto it.
thanks in advance
thanks in advance
That would be quite a mess if you removed the oil pressure switch when the engine was running. If I were to recommend doing that I would also say after oil is blowing out go in and eat lunch. When you come back you will have a nice mess to clean up and a seized engine,- oh and maybe some nice burns from the hot oil... I have seen a video where a guy removes and replaces a v belt on a running VW engine!
Some tools have the male hex on the drive end, for putting a wrench on; others don't--but they'll all have the special shape in the female end.
https://shop.snapon.com/product/Oil-...h-Socket/A119C
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/356x500/a119a_b55c980d7eb510716269ff10cdbe9ae46d81ec61.jpg)
![](https://cimg7.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/498x288/41dv_sxxccl_ac__f5989d4c73982652c8944b83dd2f4d0ed58ed974.jpg)
This one is more like what I bought about thirty years ago from the MATCO guy. Fits two sizes of switches with the goofy "hex"; I'm not sure I've ever seen the less-popular size of switch. The larger switches fit the end of the tool, the smaller switches fit the smaller wrenching surface of the tool farther inside.
I've had pipe fittings corroded on the top threads and used pen oil, a pick, small wire brush etc. to aid in removal. I've also had to apply a little heat to the surrounding area. The op switch socket is definitely a must have tool.
