oil pan leak
Old Sep 23, 2012 | 11:46 PM
louie's Avatar
oil pan leak
Since I'm pullling engine/trans to swap the trans I might as well address the oil pan leak. I haven't investigated if its the actual pan gasket or rear main seal. Would like it have both on hand when I do this. Does anyone have the part number for the rear seal? Read its a 290 ford gasket 6141?
Old Sep 23, 2012 | 11:59 PM
louie's Avatar
Nevermind, did some more searching and found what I needed.
Old Sep 24, 2012 | 12:51 AM
dancutlass's Avatar
glad that you found it!
However you should include, which engine you have in your next questions
Old Sep 24, 2012 | 01:31 AM
louie's Avatar
BS-6141 appears to be valid for all small blocks 260-403. In this case is a was a 350
Old Sep 24, 2012 | 04:06 AM
Just to make this thread complete, for anyone searching in the future,
There are two seals that will work for the small block.
Some say that the AMC seal fits a bit better, but it has two "wings" that have to be cut off before you use it.
They are:
Jeep / AMC / International 6 cylinder -
196, 199, 232, and 258 cid
# RM 13879 or FelPro # BS13879
Ford "Y-Block" V8 -
239, 256, 272, and 292 cid, but NOT 312 or 390
FelPro # BS6141
Redog
Oct 20, 2015 03:29 PM
465stroker
Jun 30, 2015 09:20 AM
bspaulding
Jun 1, 2015 05:51 PM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
