Oil Light
The oil light comes on because of a loss of oil pressure, not a lowering of the oil level. You measure that with the dipstick.
I'm no expert here, but if this were my car, the first thing I'd do is replace the oil pressure sensor and hope that fixes it. They're a few bucks at the auto parts store, and they can go bad. But if the light still goes on even with the new sensor, then I would get an actual oil pressure gauge and hook that up. You want to know what the oil pressure actually is. If your engine is experiencing a loss of oil pressure, there are several possible causes. How many miles on the engine?
mice driven it twice today first time 30 minutes light never came on. Second time it came on after 25 minutes or so. I just started it again to pull it into my garage. It didn’t come in at first but then did as I pulled it into the garage.
ill try changing the oil (haven’t done it this year) and maybe put something thicker in it. As long as it lasts this year that’s all I care about. The 350 rocket is going back in next winter.
Well there's a problem that's separate from the possible low oil pressure issue. You can't let rodents have unlimited use of a motor vehicle as they will just go joyriding in search of cheese. Next thing you know the Wisconsin State Police will notify you they have impounded you car.
If it stays on above idle and sounds good, it’s probably just the sender. To rule out a short unplug the sender when the light is on, it should extinguish.
If there wasn’t enough pressure to open the switch at cruise I’d expect the engine to tap and or knock.
Good luck!!!
Good luck!!!
lol darn iPhone.
Good luck!!!
Good luck!!!
One question, what happens if you shut off the car after the engine warms up and then a minute later restart it? Does the light come on immediately?
If the car is cold when you start it, this is expected behavior. When the engine is cold, the oil is thicker and the pressure higher. Once the engine warms up, the oil thins a bit and the pressure decreases.
If you held a gun to my head, I'd say I suspect that the sender is OK and the problem is the engine. But like I said earlier, the first thing I'd do is replace the oil pressure switch. They're less than $10, and it's a five-minute job. Do that and then tell us if the light still comes on the way it did with the original switch. Until you do some actual troubleshooting, all we're doing here is guessing.
I'm guessing the sender is bad, because it only takes approx 5psi to open the switch to turn the light off. If its been driven regularly at less than 5psi oil pressure it would be tapping or knocking.
As posted earlier, don't overdo it with thick oil, that can increase pressure but at the same time reduce oil flow/volume and make for hard cold starts.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Ok thanks.
Took her out today for about 45 minutes. Made a few stops. Mostly country driving with a bit of city stops and starts and the light never came on. Popped the hood after to make sure the sensor was connected, which it was.
I’m getting a new sensor put in when I get my gears changed in the rear end. This is also a temporary engine in the car. Do I want to blow it up? Nope, would I care if I did? Nope.
One thing I didn't see mentioned ( though maybe I missed it) is if the wire going to the switch has bad insulation or is pinched,etc, it can hit a ground and illuminate the light. I had that happen before. It can be likely on a car where the engine has been changed,etc.
72Blazerod
Jan 1, 2015 10:04 AM
