Oil filter touching headers
Old Apr 17, 2010 | 02:03 PM
jtriggy's Avatar
Hi,
Restoring my 1970 Olds Cutlass 350. Installed new hedman headers and now the oil filter is slightly touching the headers.
Is this a problem for anyone or should I not worry about it?
Thanks,
James
Old Apr 17, 2010 | 02:27 PM
Dave Siltman's Avatar
I would recommend trying to "fix" the problem. The oil in your engine is not only there to lubricate but also to dissipate heat. The last thing you want is to make it hotter. You didn't mention where the actual contact is---try to use a smaller (standard size) filter if possible. Try to tweak the header tube if need be. Hedman is a pretty good brand and I'd think they would or should fit as intended. Are you 100% positive you have the correct part #? How about a remote oil filter---easy to install, inexpensive, and should solve the problem.
Old Apr 17, 2010 | 05:23 PM
jtriggy's Avatar
Thanks Dave. Good ideas. The filter that is on there is ginormous so maybe I can get something smaller. If I can't, I'll look into relocating. I certainly don't want to mess/tweak with the headers...they cost too much and they are coated.
cutlassjim
Oct 30, 2017 07:39 PM
Shelley
Jun 26, 2013 08:36 AM
68 lemans
May 13, 2013 09:04 AM
defiant1
Aug 26, 2011 09:45 AM
