not shifting gears with new carb and manifold!
Old Jul 11, 2007 | 01:12 AM
nohn's Avatar
I am at a loss here. I installed and new 4bb Edelbrock carb and preformer manifold starts without a problem and sounds good. The problem is when I took it for a drive it didn't switch gears. I tried to pick up speed to see if it would shift but nothing changed. I did put it into low gear and then back to drive and it felt like it changed into 2nd gear. Does anyone have any ideas or is it possible I may have missed hooking something up?
Old Jul 11, 2007 | 05:22 AM
Oldsguy's Avatar
Past Administrator
The TH400 requires a vacuum signal to operate the kickdown mechanism, the TH350 uses a mechanical linkage from the carb. Did you miss either (don't know which you have).
Old Jul 11, 2007 | 10:10 AM
Not quite. The TH400 uses an electric solenoid valve for kickdown, the TH350 uses a cable. Both transmissions, however, use a vacuum modulator as a way to sense throttle position and load. Failing to reconnect the vacuum modulator line will cause the trans to only upshift at wide open throttle. That's not a problem for ME, but normal drivers may not like this...
Old Jul 22, 2007 | 10:57 AM
nohn's Avatar
Thanks for the feed back. I finally had a chance to look over my reinstallation of my carb and manifold and found I had the transmission hose in the wrong port. For the most part everything is good. I did notice when I accelerated on the highway it doesn't down shift. Also when I was testing the acceleration I seemed that I couldn't go faster the 95 mph. Any idea what could be causing this to happen?
hookem horns
Jan 29, 2015 10:53 AM
monzaz
Drivetrain/Differentials
Aug 7, 2014 11:12 AM
Chris J
29
Oct 18, 2013 08:56 PM
Beob
Aug 6, 2012 12:13 PM
GothamCity
Mar 22, 2010 12:08 PM
