(Not a) 350 Chevy Small Block?
Old March 11th, 2010 | 03:31 PM
justagirlfromla's Avatar
Today at goodyear they said the engine is a 350 Small Block. Is this normal in a 1970 Cutlass?
Old March 11th, 2010 | 03:37 PM
gearheads78's Avatar
car guy
It is a small block Oldsmobile probably a 350. It is a newer motor or at least the intake manifold is newer because I see an EGR valve that was not installed on 1970 models.
Old March 11th, 2010 | 03:38 PM
cutlassefi's Avatar
Sure looks like a 350 Olds to me! Can't tell you how many times over my many years I've had "mechanics" tell me that 350 Olds, Chevies, Buicks and Pontiacs were all the same. Just consider the source.
Old March 11th, 2010 | 03:55 PM
citcapp's Avatar
I agree its an Olds engine. I would be concerned if they don't know the difference how can they know how to work on your car?
Old March 11th, 2010 | 04:02 PM
Limey's Avatar
take it back with a smile and say HOW CAN A SBC HAVE AN OLDMOBILE OIL FILLER TUBE IN THE BLOCK ?? THATS THE OIL FILLER TUBE RIGHT NEXT TO THE RADIATOR HOSE AND WOULD DEFINATLY NOT LET THEM WORK ON THE CAR IF THEY CAN'T TELL A OLDS MOTOR FROM A CHEVY LMAO
Old March 11th, 2010 | 04:05 PM
compedgemarine's Avatar
Personally I would change out the air cleaner to a standard round element type. I have had lots of issues with that one you have. the engine is an Olds but if that is the original intake then it is a later model. not that that is bad or anything. it looks like they cleaned it up pretty nicely before they put it in and if it runs smoothly with no smoke then it will likely run forever with basic maintenance, they are pretty tough engines.
Old March 11th, 2010 | 04:08 PM
I'm changing the air cleaner LMAO for one its not even bolted down, while i was @ Goodyear, the wind blew it off :::rolling eyes:::, the last owner did some shady shortcuts, im finding out new things daily LOL. Im going to get a round chrome one. Any suggestions? Yea....i don't know about those guys. I am going back just because one of the guys keeps volunteering to do free stuff I need (i know, im bad!) but I will definitly say that Limey!
Old March 11th, 2010 | 04:10 PM
Limey's Avatar
YEA i will back ya on this one that element does not let it breathe like it should the foam in there is kinda dense , they offer a lot of different ones out there but my opinion only, and it doesnt ness hanve to be a stock one K&N offer alot of good choices
I have used with great results the K&N Extreme air filter set up
let me grab a pic to show
Old March 11th, 2010 | 04:37 PM
Limey's Avatar
and this is the top I ran I liked the black better against the blue of the motor, yes my chevy was blue motor sorry that's the way I bought it
BUT I AM ALL OLDS NOW
Old March 11th, 2010 | 04:40 PM
henryk8398's Avatar
Hangin' out...
Hands down, the oil filler tube is the dead giveaway that you are dealing with a small block Oldsmobile. The other tell-tale item is the very wide intake manifold. Beautiful car!
Old March 11th, 2010 | 04:56 PM
Definitely want the chrome, did you buy online or in a parts store? Why is my engine blue anyways? Was it stock like that or did someone paint it?!
Old March 11th, 2010 | 04:58 PM
Limey's Avatar
thats a stock color for olds and I bought mine from jegs right around 149 for the set with just the chrome you want the link ??
Old March 11th, 2010 | 05:00 PM
Sure! Man those goodyear guys are idiots then! They said I shouldnt buy it just because the "guy" painted the motor blue......WoW. I'm going to a car show soon to try and find a real mechanic
Old March 11th, 2010 | 05:23 PM
Limey's Avatar
here ya go Anthony (<<===real name) since were gonna be neighbors and all LMAO
And if you go with the 4" one measure first to make sure you will have the hood clearance that is needed for the taller filter
http://www.jegs.com/i/K%26amp%3BN/599/60-1400/10002/-1 == $95.99 2 5/16" filter
http://www.jegs.com/i/K%26amp%3BN/599/60-1410/10002/-1 == $113.99 4" filter
Old March 11th, 2010 | 05:27 PM
weathers getting warmer so the car shows should be starting up. talk to people there with Oldsmobiles and I am sure they can point you to a good local shop to work on the car. that and seeing others cars will give you a good idea of any changes you may want to make in the future.
Old March 11th, 2010 | 05:31 PM
once again thanks Anthony How do I measure the clearance LOL
Wow! Expensive! The one i have i found online for $16 LMAO i didn't buy it, came with the car!
Old March 11th, 2010 | 05:58 PM
67 Cutlass's Avatar
Great lookin car! Sorry, but don't care much for the rims & tires.
Get away from that place where you brought your car. Hate to see anyone steered in the wrong direction and spend ridiculous$$ when it wasn't called for.
You're in good hands on this site to help you with your Oldsmobile homework. Stick around, it only gets better! LOL!
There's a lot of great info on this site to learn from, a lot of great knowledgeable people to learn from too and help you save some $$ at the same time.
Old March 11th, 2010 | 06:54 PM
Limey's Avatar
thats the tricky part have to have some hold the hood while you stick your arm and head under the hood ...........................
Old March 11th, 2010 | 06:56 PM
Limey's Avatar
no really open your hood put a 1/4" slat from inner fender to inner fender and measure from base of old air cleaner to the bottom of the piece of wood
you can go to any lumber store tell them you want a 5 foot section of 1/8" slat they will know what you mean
Old March 11th, 2010 | 07:02 PM
Wow much easier! I was thinking of putting tupperware containers on the air cleaner and if the hood hit it = too big, no hit = ok ..... LOL leave it to a blonde
Old March 11th, 2010 | 07:07 PM
Limey's Avatar
thats not a bad idea either though pretty good thinking actually you are on your way to gear head yet I KNEW I LIKE YOU FOR SOME REASON
Old March 11th, 2010 | 07:38 PM
firefrost gold's Avatar
ebay has some good priced chrome air cleaners that come with a filter and all
Old March 11th, 2010 | 07:42 PM
Limey's Avatar
not being K & N which you will NEVER have to replace the filter again as long as you take care of it and oil it like your suppose to
Old March 11th, 2010 | 07:50 PM
Warhead's Avatar
Yours should actually be a gold color, Oldsmobile did not go to that engine color until 1978.
Glad to hear you will never go back to that place again.
Arm yourself with some knowledge from this site, and when a potential mechanic opens his mouth, you can tell right away if he knows his stuff, or he stuffs his nose.
They always assume young people don't know squat. Makes you wonder what they are really trying to sell.
BTW, safety tip... when you pop the hood for a peek, don't let the hood tooth bite the back of your skull.
Many a 68-72 Cutlass owners have the scars that bear this truth.
Good luck,
Jim
Gold is the correct color for 1970, but it appears that it was painted the blue that came in the mid '70's, which that engine may be.
Old March 11th, 2010 | 11:18 PM
hahahha WarHead! It has already happened! First I couldnt figure out how to pop the hood, then i got hit on the back of the head! Twice! I'll check out eBay too. I'm going to a few car shows in the next few weekends and hope to get some good ideas
Old March 11th, 2010 | 11:33 PM
Limey's Avatar
if you just want something to replace the old one go with one of these
$28 bucks to your door
http://cgi.ebay.com/ebaymotors/14-Ch...item563a3cabc1
Old March 12th, 2010 | 12:15 AM
Bluevista's Avatar
Registered
The hood tooth attached to the hood ended in '70 so you don't bash your head on the '71's and '72's.
If you post the engine casting and serial numbers somebody will tell you exactly what it is or you can figure it out with the Wiki info.
The casting numbers are just behind the water pump on the top of the block, not the manifold. The serial munbers are on a machined pad on the left front side of the block
http://www.oldsmobilewiki.com/index....Identification
Looks like you need the upper radiator hose to the radiator top plate hose retention clamp?
Cutlassgal just bought one for her car, must be a girl thing.
Keeps the fan blade from hitting the hose.
I have the 28 dollar type air cleaner for for go and a stock one I use for show, the housings can be whatever but the filter element is what's important.
Getting guys to work for free?, did you talk to Cutlassgal?
I taught my daughters to take guys for everything they got if they ask for it so no problem here.
I volunteered to help Sandy with her car but it's a car guy thing and she lives 20 minutes away, plus she's helpless...like a fox.
What Sandy doesn't know yet is that she has to mow my lawn all Summer in return, and weedeater it, once weekly at least.
Old March 12th, 2010 | 04:56 AM
rcdynamic88's Avatar
I know everyone has their own tastes for what looks good, and some folks probably like your wheels. But if that were my Cutlass those would have to go. They look like they belong on one of those "dub" cars that are jacked up in the air like a 4 wheeler. That car would look awesome with some good old Crager SS or some American Torque Thrusts.
Old March 12th, 2010 | 07:46 AM
The ?alternator? is in the way of the serial number, I can only see the last 3.
Here is #'s that were on TOP of the engine a few inches in front of the air cleaner:
Old March 12th, 2010 | 07:59 AM
  #31
cutlassgal's Avatar
Cutlass Lover
.....Getting guys to work for free?, did you talk to Cutlassgal?
You crack me up!!! I told ya, I got shows to attend and trophies to win this summer.... I'll bring the big tractor - should have it done in no time!
Old March 12th, 2010 | 08:03 AM
  #32
Here is the only thing I can see on the drivers side:
Old March 12th, 2010 | 08:18 AM
  #33
70 cutlass s's Avatar
The casting numbers is towards the front of the engine behind the water pump on the self to left of the oil filler tube. Its the right if your standing in front of the engine looking towards the car.
The numbers on the head would be right under that bracket. You can go the the pass side and look on that head. It would be all the to the back of the engine. Same area as the other head.
Old March 12th, 2010 | 08:30 AM
  #34
I looked everywhere, there is nothing on the passenger side at all. The front has a big "16" on it. The back the engine like close to the dashboard behind the air cleaner was this:
Old March 12th, 2010 | 08:40 AM
  #35
That's the firing order. If you look for the casting numbers for the block. They are in front of the intake behind the water pump in between the oil filler tube and oil sending unit on the self area. The number for the 350 should be 395558. You might have to clean the area to see the number.
Old March 12th, 2010 | 08:43 AM
  #36
LoL i hate to say this but i have no clue what any of that stuff looks like LMAO ahhhhhh the intake is the air cleaner right? and oil filler is the thing with the black top?
Old March 12th, 2010 | 09:09 AM
  #37
The air cleaner is on top. The carburetor is under the air cleaner. The intake is under the carburetor.
The oil filler is where you put your oil in the engine. It is the tube sticking up on the front of the engine.
Old March 12th, 2010 | 10:33 AM
  #38
omg so i went to the exact place you said and this is what was there:
same pic as earlier but clearer and a big pic of the area:
Old March 12th, 2010 | 10:39 AM
  #39
it says:
X 6 7
411990
cant read the letters/number under that all that well
Edit: and from googleing that # i take it its the Olds Factory Intake #..... grrrr thats the only thing i can find!!!
Old March 12th, 2010 | 10:46 AM
  #40
I hate to tell this, but that's not the numbers I was talking about. Your getting closer just a little more forward. Look under the radiator hose next to the oil filler tube on the flat self area.
