No oil pressure on my 70 Cutlass 350ci
Old April 18th, 2022, 04:15 PM
salb203's Avatar
I started a thread on Facebook about 7 weeks ago (I had to finish installing power steering in my 58 Impala before I started to work on my Cutlass) and I received a lot of replies on it from removing the engine to replace the oil pump without pulling the engine out. One reply was to remove the distributor and spin the oil pump shaft to see if I get oil pressure and low and behold I had oil pressure on the factory dashboard gauge. My next step is to remove the oil filter and cut it open to see if there is any broken pieces inside. Any opinion on how I have oil pressure when I used a drill but no pressure when the distributor was spinning the shaft.
Sal
salb203 is offline
Old April 18th, 2022, 04:30 PM
Sugar Bear's Avatar
What engine are you working on? Provide some information leading up to this situation. Is there sufficient oil in the engine?
Good luck!!!
Sugar Bear is offline
Old April 18th, 2022, 04:34 PM
Good luck!!!
70 350...title and 1st post
Vintage Chief is offline
Old April 18th, 2022, 04:36 PM
salb203's Avatar
350ci Rocket, Oil level was fine. I started the car to go for a drive and I heard the lifters making a noise. Day earlier I drove 40 miles on it. Drove in the garage with no lifter noise, next day lifters were making noise.
salb203 is offline
Old April 18th, 2022, 04:38 PM
salb203's Avatar
Norm, what do you mean?
salb203 is offline
You're sure the driveshaft is engaging the camshaft? Examine the driveshaft would be a good step - especially if a hand-held drill was able to move oil (assuming that's what you used).
Old April 18th, 2022, 04:40 PM
Wasn't Sugar Bear's question:
Old April 18th, 2022, 04:41 PM
salb203's Avatar
Can I remove the shaft by just pulling it up from the distributor hole?
salb203 is offline
Old April 18th, 2022, 04:43 PM
salb203's Avatar
Duh!
salb203 is offline
Yes
Old April 18th, 2022, 04:46 PM
salb203's Avatar
Yes
Great, I'll try that in 1 hour, my meds didn't kick in yet (Parkinsons Disease)
salb203 is offline
Old April 18th, 2022, 05:10 PM
66SportCoupe's Avatar
First why did you replace the oil pump? Now that you know you have pressure did you have no pressure before?
66SportCoupe is offline
Old April 18th, 2022, 05:15 PM
This should indicate your oil pump driveshaft is OK, since you spun it from the top of the hex, and it turned the oil pump and generated pressure. I am not sure what advantage there is to pulling the drive shaft for inspection. I would inspect the distributor to ensure the gear and the recess for the drive shaft are OK.
Now how much pressure was generated would be my next question.
Fun71 is offline
Old April 18th, 2022, 05:16 PM
OK. I got a little ahead of myself. I have several things going on around the house. The oil pump shaft must be engaged in the camshaft intermediate shaft (I called it the driveshaft) which connects to the oil pump. Sometimes the intermediate shaft comes out w/ the distributor - other times not-so-much. The oil pump intermediate shaft might have slipped out of place at some point if the distributor was removed and/or replaced. With the distributor out look down the hole with a flashlight (tough to do I know), you should see the top of the shaft, it looks like the head of a regular flat tip screw. I'm not sure what you used to spin the intermediate shaft when you pulled the distributor - I'm assuming a hand-held drill? I'm confused how the drill spinning could move oil but the distributor does not. So I was thinking the bottom of the distributor is not engaging the intermediate shaft to turn the oil pump possibly?
Old April 18th, 2022, 05:18 PM
Ah well, you beat me Kenneth. When I said driveshaft, I meant the intermediate shaft; and, yes, the key-way at the bottom of the distributor might not be engaging the intermediate shaft. I said driveshaft by mistake, meant to suggest the intermediate shaft.
Old April 18th, 2022, 05:34 PM
...you spun it from the top of the hex, and it turned the oil pump and generated pressure...
Kenneth, you're probably correct, it might be a hex, instead. I thought earlier distributors had a different key. At any rate, agree that key needs to engage the intermediate shaft.
Old April 18th, 2022, 05:44 PM
OLDSter Ralph's Avatar
Originally Posted by fun71
this should indicate your oil pump driveshaft is ok, since you spun it from the top of the hex, and it turned the oil pump and generated pressure. I am not sure what advantage there is to pulling the drive shaft for inspection. I would inspect the distributor to ensure the gear and the recess for the drive shaft are ok.
x 2
OLDSter Ralph is offline
salb203
April 18th, 2022 05:10 PM
jensenracing77
April 7th, 2019 10:39 AM
chevyguru86
March 18th, 2016 08:19 AM
J-(Chicago)
May 28th, 2014 03:03 AM
chrisntam
July 31st, 2013 07:46 PM
Quick Reply: No oil pressure on my 70 Cutlass 350ci
