New OldsRocketParts SBO 6" Rods
I happen to run across an ebay auction that is listing new, aftermarket 4340 steel 6" I beam connecting rods for 307-403 engines:
http://www.ebay.com/itm/OLDSMOBILE-3...39ad9d&vxp=mtr
The seller has a low number of feedback, which has me a touch worried, but seems the website has been up for some time.
http://www.oldsrocketparts.com/produ...eam-race-rods/
Does anyone have info regarding this seller or the rods?
I asked:
Dear oldsrocketparts,
are these eagle rods? thank you
Response:
NO, THESE ARE HIGH PERFORMANCE ULTRALITE .
- oldsrocketparts
If they fit with no extra work, that is a huge bonus. Is there a reasonable price floating pin for Olds? I assume if it is the same size as the Probe or CP, they would work. Reasonable price for a decent rod.
Imagine that ,someone else actually thinks that the SBO deserves a drop in stroker crank. We can only hope that .....
1.these products come to market within a reasonable amount of time
2.they're affordable for the average guy
3.they're quality pcs.
The big block intake they sell looks to be a re-cast of the Mondello Posi-Flo with added fuel injector bosses. Mondello's intake was actually an Offy Port-O-Sonic without the Offenhauser cast-in lettering.
I'm in the market for a set of OE style rods, wish I had more info on these. I did email, but have yet to get a response.
The concerns I have is that the face of the big ends have a shoulder, as if it was made for a steep radius/fillet, which to my knowledge Olds doesn't have. It looks like it would require a special chamfered rod bearing.
Maybe the pics aren't accurate, and are just a on-hand photo of like a chebby rod or something.
Think I will try calling today, see what's up. The low feedback is still bugging me some.
For $400, it's almost worth just getting a set to do a closer inspection.
Allegedly Lynn Wilfringer, Mondello Performance Products:
http://realoldspower.prophpbb.com/topic2531.html
I should be worried? I will have these checked out thoroughly, and obviously, I pulled the trigger.
Have another thread going over at ROP:
http://realoldspower.prophpbb.com/post22589.html#p22589
Sorry for not closing the loop on this thread, I had threads on multiple Olds sites, and guess overlooked this one.
True, I sent them back, they didn't pass a visual inspection. They were not new, had damage from poor packaging and/or handling, the side clearance measurements were all over the place, as well as the small end dimensions. They were sand/media blasted until there was no marking left on the bolts, and the mating surfaces would require at minimum a touch up.
I have pics showing all this and more detailed info on the other threads.
In other words, they were not new, not as advertised, not OE specs, and not going in my engine. I sent them back.
I couldn't find that part number for the Hastings, but I do like Hastings rings.
I picked a Total Seal Conventional Classic Race (CR) set for the clone/Olds/Probes, felt it was the best choice. I did file fit, but the sets already sized are fine too, even if you want to run 150hp or less of spray.
I think the part number I used is CR3690-95, but don't quote me on that, I'm pulling that straight from memory, and my memory isn't that good these days. If you want, I can dig up the part number.
I bought a set of those 4340 forged rods from oldsrocketparts.com, also picked up a set of heads from them too, they should be here in the next couple of days. Staying optimistic... also bought the floating Probe 4.087's and a set of file-to-fit Total Seal plasma-moly rings. I've got a virgin 330 crank, taking it in and going .010/.010. Again, staying optimistic...hoping to build an "arguably" bullet proof short block. If these rods don't work out, I'm going with the Chevy rod setup.
I bought those rods from oldsrocketparts.com. The small ends were within spec without needing new bushings. However, they will need to be balanced and definitely DON'T use the bolts they come with. Toss 'em right in the garbage and get ARP bolts. I also used Probe pistons, a Comp Cams hydraulic roller cam, totally reworked the stock #6 heads with bigger valves and had them ported. Considered going with Chevy rods but you'll have to have extensive work done to the crank. Unless you can find someone who will GUARANTEE the crank work . . . be careful.
Thanks for the info. folks. The rods and heads are in. Mic'd the rods, all 8 are .979 & 2.249 respectively and true. Really nice "looking" rods. The heads are just as nice. The heads were well packaged, the rods weren't. The rods were in individual small bubble wrap bags and all were loose in a USPS box with what appeared to be hand torn cardboard dividers, that at the point of delivery served no purpose. Next stop, the machine shop. Having them look everything over. Probe pistons are about 2-weeks out, back ordered.
Check the big end widths. Are there knicks all over the big ends? And the bolts look the same as the ones I had, check to see if there's manufacturer markings or if they're bead blasted off. Is that rust on the bolts?
Did you use a caliper mic, or a bore gauge? If a bore gauge, then you should take readings across the face of the bearing surface, to check for taper.
I swear those look like the same set I had. I wonder if they keep getting returned and re-sold.
Happy Hot Roddin'
The set I had were all over the place, some were down as far as .923 width on the big end. You probably should at minimum replace the bolts.
I'd be curious as to what your machine shop says about them, please post once you hear from them.
Here's the thread from ROP on my set:
http://realoldspower.prophpbb.com/topic2418-30.html
Can look at some of the pics, like I said, I think they are the same set, and people keep returning them. Certainly not new, which is how they were advertised.
There are a few small nicks from where they were improperly packed.The widths on the big ends are .928 within maybe .001. The bolts are stamped 8640 (190,000 PSI) ARP 8740 rod bolts are 200,000 PSI. They aren't perfect, but they're close IMO. I'm using them, The options are very little, and I'd rather not cut up my crank for Chevy rods if I don't have to.
Happy Hot Roddin'
Happy Hot Roddin'
Glad you had good results. I contacted them twice, asking questions and all I got was an attitude and then no response. If they check out at the machine shop, he may sell another set real soon.
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
