new and need some help
Old Jun 9, 2007 | 05:00 PM
bonesbmx's Avatar
hi
i just want to say this is a great site
i have a 1972 cutlass supreme runs great today the overflow coolent was boiling just wondering where i should start im thinking thermostat what else could cause this?
also noticed some gime build up in my rear drum brakes is this the wheel cylinders or the axle seal?
any help would be great
thanks
Old Jun 9, 2007 | 06:33 PM
Oldsguy's Avatar
Past Administrator
hi, welcome to our site. There are quite a few reasons for overheating; low coolant level to begin with, old radiator, bad cap that doesn't hold pressure, are a few that come to mind. Have your cap checked, flush the system and refill. Those are two things that don't cost much and could solve your problem. The second problem could be a leaky cylinder. Take off the drum and look at the backing plate, is the stain from the cylinder down? If so, that's your answer.
Old Jun 10, 2007 | 04:33 AM
bonesbmx's Avatar
i just put a new rad, cap and fluid in 2 summers ago could the cap be defective? how would i check?
thanks
Old Jun 10, 2007 | 06:21 AM
Ranzan's Avatar
Getting There
do you have any heat coming out of your heater? if not the thermostat could be bad
Braxton
Mar 23, 2015 04:31 PM
marxjunk
Sep 24, 2014 03:20 AM
71cutlasslover
Mar 23, 2010 11:33 AM
pheezy
Feb 8, 2009 04:53 AM
billy_bob76114
Dec 13, 2006 02:47 PM
