Need Help. Building a Roots Blown 350, How?
Old Nov 13, 2015 | 07:40 PM
  #41
jbarnett's Avatar
What piston and stroke are you planning to use along with the 6.200 Rod?
I'm not stroking the motor but wanting to go to the 4.125 bore with the 2.100 rod journals. But when doing the math (with the online calculators) with the available choices in compression height for forged pistons (albeit through Summit) to get around the desired compression ratio (8 to 8.5) using 77cc heads I had to look at 400 pistons for a 5.7 stroke but using a 6.200 rod. The idea that I am off on something along the lines is quite possible though.
Olds pistons are usually in the 1.6ish range om a 6.000 rod for compression height yes?
The math I used was:
Deck Height = 9.330
Bore = 4.125
Stroke = 3.385
So:
6.000 rod length
(0.5 x Stroke) 1.6925
1.6375 = Compression height
6.200 Rod length
1.4375 = Compression height
I'm working with a builder but this is all for me to learn.
BTW, this forum needs stickie/permanent threads with info at the top bad. A basic tech one, common build one, etc. I'm surprised there isn't any.
J
Old Nov 13, 2015 | 08:40 PM
  #42
wr1970's Avatar
Good ideal on sticky but someone has to carry the ball to the moderator and changes can get done. Guys in the know would have to furnish info.Then it would benefit those who don't.JMO
Old Nov 14, 2015 | 04:18 AM
  #43
cutlassefi's Avatar
Look for a piston with a dish around 12cc and a cd of 1.425. That'll give you about 8.3 with a 77cc head and a little deck clearance.
Even with just a little boost I'd deck the block to clean it up though.
And you'll need to pay close attention to the alignment on the small end of the rod going up into the piston. Olds rods are centered, Chrvy rods are offset.
By the way, your builder should've known all of this.
Old Nov 14, 2015 | 11:53 AM
  #44
jbarnett's Avatar
Thanks.
I'm sure he does but this was really for my benefit, not his. I can have just told him what I was looking for and he could do it but I don't like to just have someone do everything for me and be entirely oblivious to the process.
It was also to help me know on a simple parts basis where to look from some manufacturers.
J
Old Nov 14, 2015 | 01:49 PM
  #45
jbarnett's Avatar
Here's a couple photos of the car in case anyone was curious.
Before and after.
Old Nov 15, 2015 | 10:05 PM
  #46
1BOSS83's Avatar
Wink
Deck Height = 9.330
Bore = 4.125
Stroke = 3.385
So:
6.000 rod length
6.200 Rod length
J
You'd never get everyone to agree to the same parameters of the permanent threads
Old Jul 11, 2017 | 03:26 PM
  #47
jbarnett's Avatar
Update:
As with many projects, this one has been shelved for a bit as other ones got in the way.
Short block is finished though and I went with a set of 8 heads and had them opened up some, new valves (with 3-angle valve job), springs, and combustion chambers polished for a bit of extra CC's and reduction in detonation. Dick miller main caps and girdle installed on the bottom end and ARP everything. Should be just under 8-1 static compression.
Schneider custom ground hydraulic roller cam set up and lifters.
282-RH HYDRAULIC ROLLER CAMSHAFT
282 DURATION
230 @ .050" LIFT
.576" LIFT WITH 1.6 ROCKER RATIO
114 LOBE CENTER
Got a Hampton 6-71 unpolished set up for the supercharger. Intake will be port matched to the heads. Still need to have the crank broached and 2nd key way installed and dampener machined for the 2nd key way as well (don't want to risk shearing!)
J
Old Jul 11, 2017 | 06:34 PM
  #48
olds 307 and 403's Avatar
Out of Line, Everytime😉
Cool, what pistons were used?
Old Jul 12, 2017 | 03:53 AM
  #49
cutlassefi's Avatar
Single pattern cam?
Ctott70
Dec 31, 2010 07:06 PM
twintracks
Sep 18, 2010 06:32 AM
bennymac
Apr 12, 2007 07:11 AM
elisowski
Sep 15, 2003 07:46 PM
