Need a different water pump pulley
Old May 20, 2020 | 11:25 AM
cjsdad's Avatar
As I get little bits of time to work on the Hooptie I find little things that require "adjusting" in order for the new engine to get running. I cleaned and repainted the pulleys and put them on the engine but there's an issue here. The water pump that Mark installed to make sure the engine stayed cool is a bit longer than the stock 330 pump on the original engine. I can find them in chrome finish or billet aluminum, but not factory black. Anyone have the part number for the long pulley? Or have a spare they are willing to part with?
Old May 20, 2020 | 12:49 PM
ajr2820's Avatar
Pretty sure you need the short water pump.
Old May 20, 2020 | 01:21 PM
^^^THIS. Your engine should have a 5.1" water pump.
Old May 20, 2020 | 01:33 PM
RocketDevo's Avatar
The longer shaft or HD water pump you have requires the offset "KM" pulley in order for the belts to line up.
I think In Line Tube sells them.
Bitburger
Dec 21, 2024 06:03 PM
Torqueline
Sep 16, 2017 09:21 AM
TEP
Oct 19, 2016 07:32 AM
rcrac3r
May 23, 2013 12:08 AM
Ablast
Apr 21, 2013 07:38 PM
