mysterious rubber flap in front of radiator ?
Location: from Wisc, then Texas, then Kansas, now back to Texas,
in front of the radiator, inside the grill, on the left side (drivers side) is a thin rubber flap about 8 or 10 in. square...... where does it go ? one corner of it is still fastened to the upright
''shroud'' near the rad support it has about a 1'' hole in it with a 'slit' to the edge. The one for the other side is missing..I assum I need these for air flow control. ???????????????
They sell them repro but I don't recall what they are called. They are meant to direct airflow thru the radiator & not around it. On a '70 the bottom goes to the radiator support & the top goes to the radiator top plate. IIRC '70 had two different sizes for standard or heavy duty cooling.
I have to wait a few days now for a new radiatror, so now wouldd be a good time to put them in............Year one or OPG shuold have them , I would think, if now I only knew what they are called ..........
There is also a flap that fits around the park light on a '69 to keep crud off the light housing that is projected forward from the rotating wheel assembly... The one inch hole with slit goes around the bumper brace and surrounds the light housing...play with it, you will figure it out.
Last edited by Yellowstatue; May 7th, 2011 at 03:11 AM. Reason: Intelligence update!
