My pistons
Old March 26th, 2009, 08:00 PM
1973oldsomega's Avatar
My pistons
Here are some pics of my pistons lets see if i can figure out how to get them here.
1973oldsomega is offline
Old March 26th, 2009, 08:03 PM
Old March 26th, 2009, 08:05 PM
Old March 26th, 2009, 08:08 PM
Well i figured it out they are just huge pics lol. So here is the question there are two different sets of rings that i can get from summit. Which ones should i go with. Here are the links to them.
http://store.summitracing.com/egnsea...DS=1&N=700+115
or the High performance
http://store.summitracing.com/egnsea...&N=700+0%2B115
Old March 30th, 2009, 12:04 PM
Found out so crappy news. I already had some of my engine back together. I had the new cam installed i have the crank in and the timing chain and gears installed and the front plate and water pump installed. Now i find out from the engine shop that i will have to get my rotating assy balanced since i got new pistons. Now i have to take what i have put together back apart not a real big deal just a *** pain more then anything. Does anyone really post on this site i see post from back in 2006 that never got answered mabye i post in the wrong forums.
Old March 30th, 2009, 01:55 PM
85olds442's Avatar
Thumbs up Pistons.......and Rings.......
You are correct!!! You will need to have your rotating assembly balanced. This does a couple of things. First and foremost, it will make sure that your engine is balanced, thus improving it's life expectancy, second it will not vibrate, causing pre-mature bearing wear and possibly failure. I would contact Dick Miller for the engine rings, ( he has zero gap rings ) little more money but more HP and better sealing. I have an olds 350 .30 over bore with 11/1 comp ratio and used his rings with get results. Also had my rotating assembly balanced and it runs AWESOME!!!!!! Hope this helps....
P.S. There are not alot of companies that have rings in that size. This is what I have found out.
85olds442 is offline
Old March 30th, 2009, 01:58 PM
cutlassefi's Avatar
Pistons
I see by the first picture that you didn't bore it? Why would you buy new pistons and not bore it when you can see ring wear in the cylinders?
Whenever you change just about anything you always need to recheck the balance, especially if you want to do it right.
cutlassefi is offline
Old March 30th, 2009, 02:00 PM
85olds442's Avatar
Rings.........
Just a note I am using the same pistons as you have but mine are .030 over.
If you are on a budget use the moly rings from summit. If you can have a few extra bucks go with the zero gap rings from Dick Miller Racing. Just Google his name and you should be able to find his contact info.........
Old March 30th, 2009, 02:13 PM
BobsW32
Bobsw32's Avatar
I see you are running a high volume oil pump.....Just make \certain you use a pan that has extra oil capacity as that pump can suck a standard pan dry.......
Bobsw32 is offline
Old March 30th, 2009, 07:45 PM
Well the engine shop owner said that it didnt need to be bored over he said it was in good enough shape to just hone it out and there is no need to bore an engine over unless it needs it. So he has been doing his job and running his business for over 20 years i just listened to him.
Old March 30th, 2009, 07:46 PM
Yes i know Dick Miller Racing i ordered my fuel pump block off from him and also my motor mounts i will look into the rings thanks.
Old March 30th, 2009, 07:48 PM
Yes i got the high volume oil pump and the moroso oil pump pickup i am just waiting on the funds to get the oil pan i got the part number for the one i have to order to fit to the setup i got right now. I just can not get the oil pan until i get my rotating assy balanced now i didnt see this one coming but i guess these are the kind of things that happen during a build huh.
Old March 30th, 2009, 07:55 PM
Well what should i do. Send the pistons back and get some .30 over pistons and have the engine shop bore it .30 over. What benefits will i be looking forward to doing this?????? Just more displacment right
Old March 30th, 2009, 08:19 PM
Eric Anderson's Avatar
IMHO if the engine shop checked your cylinders and found them to be within spec a hone is all you need. I can see why you would change pistons if you were going from lower compression to higher compression pistons is this your plan?
Eric Anderson is offline
Old March 30th, 2009, 08:46 PM
Well yes of course this is the plan who dont want more power right. Thanks Eric. But what exactly would i be looking forward to if i was to get the block bored .30 to .40 over????
Old March 30th, 2009, 09:00 PM
IMHO boring .30 over would not yield any performance gain worth the expense. If the bores check out and all that is required is to hone them why bore them out? Seems like you are on the right track to me.
Old March 31st, 2009, 07:35 AM
citcapp's Avatar
X2 what he said
citcapp is offline
Old March 31st, 2009, 08:28 AM
cutlassefi's Avatar
Pistons
How about just asking the shop owner what the bores actually measured out to. What will the current piston to wall be etc.? Fact is you still have shadows in the form of wear from before.
Old March 31st, 2009, 10:03 PM
Junior Member
88 coupe's Avatar
........ if the engine shop checked your cylinders and found them to be within spec a hone is all you need ........
Yep.
........ Fact is you still have shadows in the form of wear from before.
As long as the glaze is broken, shadows won't hurt a thing.
Norm
88 coupe is offline
72 Supreme
May 20th, 2008 04:06 PM
Olds71suprema
May 10th, 2008 09:44 AM
77omega
May 9th, 2008 07:25 PM
Big J
April 21st, 2007 08:31 PM
VanZant
August 7th, 2004 03:44 PM
Quick Reply: My pistons
