more power 403ci help
hey wassup yall. i need to know what can i add to my car to give it more power?
its going to be pulling 6-700 pounds extra, what can i add to the car without hurting my smog emiss, and without having to rebuild my engine, while pulling that 6-700 pounds extra, my accel was not the same... pls help all info will be needed thanks
If that is your car, I would imagine you have a 2.41, or 2.53 axle gearing at best.
Going to a 3.23 gear would be the 1st thing to do before anything else.
THEN, I would do the exhaust, heads, and cam.
Do the gears first.
It will have NO effect on emissions, and it will amaze you how much more pep it will have.
Jim
Do the gears first.
Jim
You really did not state what kind of driving, nor the transmission that is in the car.
I made a rash assumption that you would be driving it on the highway, and you do not have an overdrive. If you have an overdrive, you may want to go with a 3.73 gear.
True dual exhaust, with free flowing mufflers.
600-700 extra pounds?
Is that like 300 kilo's?
Wassup yall?
Are you taking the car from Houston to Florida in the near future?
Wassup yall?
so you mean flow masters right?
meaning i was going to put some BIG rims on there 26"s
never thought deep like that..lol
naw too far california..lol
one more thing where can i find parts for my rear end on the net?
Wassup yall?
Wassup yall?
well if it's that serious, what's up you all? i thought this was a oldsmobile classic car help forum, not a dictionary or english class..i been here longer then most. It's called text typing FYI (for Your Information)
Send a note to Brian Trick, or Monzaz. They will help you identify what you have, and get you the parts you will need to do the axle. You will probably have to get someone local for installation of the gears. In fact someone local (many 4wd shops for example), may have the parts, and service needed to do the install.
Expect a little ribbing if you speak in slang, here.
Es ist alles gute.
Jim
Es ist alles gute.
Jim
