milling 3A heads?
Old Mar 8, 2014 | 11:48 AM
simonb.'s Avatar
milling 3A heads?
hello from austria!
i am rebuilding a 350 from 1977.
it has the 3A heads. i dont want to make a race-maschine, just a solid cruiser
with (a little) more power than my old 307 had!
i will bring the block and the heads to a proffessional engine shop to do a 3 angle valve job and messure all the bores//bearing tolerances etc. and if necessary i will let it bore and get new pistons.
i have the fel pro gasket kit with the blue head gaskets.
how much should i mill the heads to get a better compression ratio?
i dont want/cant to buy better heads, because here in austria its impossible, getting the heads you want....
i have removed the air tubes and did a little porting., also i have the comp cams 260h kit with springs, timing chain etc. and an edelbrock performer.
200r4 and 3.08 posi rear.
the hole thing comes in my 76' buick skylark, so not a heavy car!
thanks for tips, simon!
Old Mar 8, 2014 | 03:15 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If he bores it oversize, get flat top or small dish forged pistons as replacements. Those heads suck on the exhaust side and are known to crack. If the heads are use able, mill them .020" if that motor is equipped with shim gaskets from the factory. I have heard conflicting info on the factory head gaskets on the 77 and later SBO.
Old Mar 9, 2014 | 12:14 AM
simonb.'s Avatar
dont know if it was equipped with shim gaskets from factory, because there where blue felpro gaskets mounted. so i ordered a complete gesket kit from fel pro, as i wrote.
how much should i mill, when using the thik fel pro gasket?
and where do those heads break ,,normally,, ? mine are still useable.
thanks.
Old Mar 10, 2014 | 09:22 AM
Supposedly the exhaust side. Mill them .020".
Old Mar 11, 2014 | 06:10 AM
Lars's Avatar
Zero deck the block and do the heads 20
Old Apr 1, 2014 | 04:49 AM
simonb.'s Avatar
thanks guys! will the performer intake fit correctly, after milling 0.020?
the engine is at the mashine shop now and i am waiting for the parts:
speed pro flat top 0.030'', comp cams 260h kit, all bearings, gaskets, oil pump.
should the crankshaft be balanced new with that flat top pistons, or will it not be necessary?
dont know the weight difference between the speed pro and original pistons.
greetings.
Old Apr 1, 2014 | 07:13 AM
Lars's Avatar
take a few days and read 2 threads, "pulling the motor" and "home porting techniques" 3A heads have some issues that can be resolved whilest there off. sounds like your gonna soop er up. this is the time to do it. and yes the performer will bolt on with 20 milled off the heads.
Old Apr 1, 2014 | 07:16 AM
boese1978's Avatar
you will need to have the rotating assembly balanced with the new pistons.
Joel
Apr 26, 2017 01:37 PM
Shaunbo13
Jan 27, 2014 04:18 PM
toms vista
Oct 3, 2010 09:13 PM
feistyfeist
May 23, 2007 01:30 PM
