Maybe a stupid question
Old Dec 30, 2006 | 04:56 PM
DonFrost's Avatar
Question Maybe a stupid question
Can I replace my CCC carb and leave the distributer alone or do I need to replace it as well?
Old Dec 30, 2006 | 06:26 PM
Oldsmaniac's Avatar
I believe you will get trouble codes from the Computer as it wont sense throttle position. The distributer I believe wont be affected....Just my 2 cent opinion.....
Old Dec 30, 2006 | 07:41 PM
grimlock's Avatar
Doesn't change anything unless you like seeing the ses light
Old Dec 31, 2006 | 04:40 AM
DonFrost's Avatar
I really don't care about the light. I can pull the bulb and replace it when a diagnosis is needed.
Now Question 2,
Should I get somthing other than a Q-jet or just buy a q-jet that is set up to my cars specs except for a year older for the non ccc?
Thanks alot for the advice.
Old Dec 31, 2006 | 06:20 AM
ozoneblue's Avatar
Exclamation SES light
Does your car also have A ALT light ?some eairly GMs used the SES light to excite the ALT,Some of the not so reputable used car dealers use to try this. Buyer Beware . Larry
Old Jan 1, 2007 | 03:59 AM
Kennybill's Avatar
I read a tech article in Car Craft or Hot Rod about this reasonally, Car lacked power, they said the CC distributer wasn't advancing properly. They told to put a non-computer distributer with a ported vacumn advance. Later, Ken
Old Jan 6, 2007 | 06:47 AM
DonFrost's Avatar
Thanks alot guys. I recently had the distributer cap off and noticed that the shaft (or at least the part that the rotor screws down to) is loose, I can move it back and forth about 15+degrees either direction. Could that create a serious idle problem? I shake bad at the stoplights when warm.
auto_editor
Apr 26, 2013 05:19 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
crazy-steve
Aug 31, 2009 06:36 AM
442_Mustang
Apr 30, 2009 06:56 PM
