Marking the distributor
Old Oct 1, 2013 | 01:51 PM
Macadoo's Avatar
Hey fellas and gals,
I'm (hopefully) going to pull my motor this weekend and am trying to plan accordingly. Do I need to mark the distributor housing and block, and the rotor direction before I yank it out IF I'm replacing the camshaft as well? I've been reading and watching videos and it seems I can do it from scratch if I find TDC for #1 cylinder. When dropping the distributor in, does it matter what position the #1 spark plug is, as long as it is aligned with the cam? Although, now that I've written this, I bought pre-cut wires so I would want them to reach so yeah, that might matter.
Any tips for dropping the distributor back in? Aligning it with the oil pump shaft, etc?
I just don't want to repeat the mistake I made with a VCR (yeah, years ago) when I messed with a factory setting and never got it back.
As always, thanks.
-Mac
Old Oct 1, 2013 | 02:23 PM
don71's Avatar
same but different
Mac, at this point just be prepared to bring the #1 up to TDC and let the rotor point where it wants to. Worry about the other things first. We'll get you straightened out when the time comes. Its really personal preference when getting all the wires etc. hooked up.
My vote...do it from scratch.
My opinion...pre cut wires are usually too long.
Oh...and hey, its not a VCR
Old Oct 1, 2013 | 02:24 PM
As long as the engine is on #1, when you drop the distributor back in the rotor will point to #1 for wiring purposes.
Old Oct 1, 2013 | 03:14 PM
Macadoo's Avatar
Sounds great guys. Thanks. And yeah, this isn't a vcr, it's a lot less complicated!
Old Oct 2, 2013 | 02:38 PM
tmaleck's Avatar
To be clear, the rotor will point wherever you want it to upon reassembly. I think they mean there is a diagram that indicates where #1 plug wire is on the cap. If you are a novice, it is possible to get it one tooth off. Given that you have worn timing parts (chain, gears) now, even if you line up to TDC and mark it before disasssembly, the marks may be no good anyway. I would go ahead and set the engine up TDC and mark it, just be aware these marks are more like guidelines, not actual rules.
Tim
Old Oct 5, 2013 | 10:57 AM
Macadoo's Avatar
Thanks tmaleck, Good point about being worn. I'm replacing the timing set as well.
costpenn
Mar 7, 2014 03:26 PM
501Paratrooper
Jun 21, 2012 06:50 AM
Al Graaf
Apr 6, 2012 01:41 PM
prrc
Jan 27, 2011 04:55 PM
