Mark47- Coil - Distributor question(s)
Car: 1971 Cutlass supreme with 350 rocket motor 95% stock. Distributor is an aftermarket Mallory Unilite (maybe 5 yrs old). I purchased the car the way she sits from a collector - it's not hacked on and was meticulously maintained, but driven very very little...hence my issues...
Situation: car has died on me twice. Both times ignition issues (no spark). First fix was replaced unilite ignition module. Worked. While testing fix I noticed coil was unusually hot. So, I kinda knew I may be headed for a problem. Died a second time. Replaced coil. Worked, but new coil is still very hot. So...
- ignition ballast? That my issue?
- what are your thought about replacing the whole older technology with a new HEI ?
I appreciate any help. I am not a mechanic, so go easy on me...
Mark47 - coil / distributor questions
The Mallory Unilite I believe requires a ballast resistor. If your car still has the resistor wire that should work also. The Unilite is a pretty decent distributor as is an HEI, they all have their quirks.
amphicar770
October 31st, 2010 05:38 PM
dan2286
February 5th, 2009 06:42 PM
